67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> Transparent Background
12 Posts No Rating |
Is there a way to make the background of a rendering transparent, so that when I bring it into Photoshop I can put a sky behind it and not have to cut out the background? Thank you
Please do a search of the forum next time. This is a very FAQ... Simply export to PNG or TIF and the resultant export will have an alpha channel for the background which you can turn off...
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer  B. Arch)
6 Posts No Rating |
It's an FQ because it's not exactly flear how this works. Sometimes it does, sometimes it doesn't. I have a transparent PNG and when I import it into an elevation - no go.
6 Posts No Rating |
So it's not as simple as many many post say. Transparency to revit is a binary state. Either it's 100% transparent or it's white. In order to get to this state - say for an underlay sketch you want to use, you need to delete the background using the erase background tool, then change the mode (assuming photoshop here) from grayscale to a DUOTONE. Then you export to web as a PNG. This is the only way I've found to reliably get it working.
Print to PDF with transparent background! |
Tue, Jan 25, 2011 at 8:12:03 AM
Transparency problem. Inserting tif's for decals, the transparent background... |
Thu, May 24, 2012 at 12:47:44 PM
Export floor plan to format with transparent background |
Wed, Jul 15, 2015 at 1:22:24 PM
Transparent pdf |
Wed, Feb 21, 2018 at 5:27:47 PM
Any way NOT to render a backround in Revit 2013 ?? |
Wed, Feb 27, 2013 at 1:57:02 PM
Members: | 1993437 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
