55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> BIG curtain wall room bounding problem!!
We use curtain walls for interieur office system walls. The problem is that the room bounding line in a curtain wall is in the center and not on the face of a panel. Resulting in a wrong square area of the room. Is there a way to place the room bounding on the face of a curtain wall, like a 'normal' wall. If this isn't posible we need to put room seperation lines in all rooms!!! Thanks Arno
You need to learn to use your HELP. Revit's help is very good and explains a lot more than we ever got with CAD. Read this topic: Changing the Room Area Boundary Location
This doesn't work on curtain walls!!!! And i do use Help!!
My advice was not a criticism. Your question did not indicate that you understood room boundry calculation settings. And you are right, room boundries on curtainwalls only appear to be at the curtainwall definition line. You can create your curtainwall so that this line is on one face and not the center.
room bounding problem |
Fri, Jul 28, 2017 at 4:03:50 AM
13
Curtain Wall & Room Bounding Dissapeared |
Mon, Jun 27, 2011 at 9:36:36 AM
room bounding parameter in wall |
Fri, Jun 27, 2008 at 10:17:07 AM
Room bounding... |
Sat, Jan 6, 2007 at 7:39:42 PM
Room Bounding - Room area changes, then changes back for no reason! |
Wed, Apr 28, 2010 at 6:22:40 PM
Members: | 1991640 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
