93 Users Online (90 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Shared Coordinates
Mon, Nov 30, 2009 at 10:02:29 PM | Shared Coordinates
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2010
I'm trying to set up two linked files, using shared coordinates. However, once I've attempted to Acquire Coordinates, every Save I perform gives me the following message:
Location Position ChangedYou have changed the position of a location in linkedfile.rvt. What do you want to do?
SaveSaves the new position back to the linked file.
Do not saveReturns to the previously saved position when the file is reloaded or reopened.
Disable shared positioningRetains the current position of the link and changes the Shared Location parameter to [Not Shared].
The problem is-"Save" attempts to modify the linked file. I was acquiring coordinates from that file. What changes there? Help file states that the linked file is not modified in this scenario. Second flaw in this is that the linked file is a workshared file, and "Save" can't write to it at all if others have modified since I started trying to establish shared coordinates.
"Do not save", doesn't save the positioning. But it doesn't get rid of the dialog on every save either. I am still prompted to choose what I want to do...
"Disable shared positioning" does what it describes, and changes the parameter to "Not Shared"- But the dialog still appears on every save, even after that. And then I don't have shared positioning, which is what I was trying to get.
I am not moving the linked file. I can open the file, save, choose disable shared positioning, save again, choose disable shared positioning again but no commands in between.
How is this supposed to work?
Tue, Dec 1, 2009 at 1:04:58 AM | Shared Coordinates
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
This is how its supposed to work:
If I have a site file with correct world coordinates or locale coordinates such as Australian Map Grid as well as the appropriate Relative Height Datum etc.
You then link in your building files into this site file.  Setting them as shared updates the shared coordinates system in the building files based on their position in the site file.  So if you rotate, change height or move, it will update the positioning in the building file.  As such if I place a spot coordinate or spot elevation or level in the building file (set to shared coordinates) it would report the same coordinate information if placed within the site file.
If you had multiple instances of the same building in the site file then you couldn't have a shared location.
Does this clarify?
Regards,
Chris.
Tue, Dec 1, 2009 at 2:54:56 AM | Shared Coordinates
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
thanks Dr. Spot
Sat, Mar 6, 2010 at 10:06:14 PM | Shared Coordinates
HSK3000
If you still need help with shared coordinates check out this link:
Revit Pro Podcast How To Deal with Shared Coordinates http://goo.gl/fb/UEqR #revitpropodcast #linksite #revit
Shared Coordinates while linking Dwg into Rvt
Thu, Jun 5, 2014 at 12:06:32 PM
Toposurface - CSV import to shared coordinates
Thu, Aug 22, 2013 at 2:59:54 PM
Toposurface, Shared Coordinates, and Contour Labels - Need Help Fixing
Wed, Aug 31, 2011 at 5:29:12 PM
Shared Coordinates Error When Saving
Wed, Sep 10, 2008 at 1:42:09 AM
Exporting sheets to dwg with shared coordinates
Tue, May 6, 2008 at 9:50:37 PM
Page generation time: 0.3141
