42 Users Online (41 Members):
Forums >> Revit Structure >> Technical Support >> Exporting a Render Image
2 Posts No Rating |
I finished a render and exported/saved it to three different places. However, when I went to look at it later I realized it never saved the image anywhere. Also, the save to project button was not working. When I pressed it nothing happened. Does anyone know why it will not let me save a rendered image anywhere? I have done other projects and used this command fine in the past.
2 Posts No Rating |
I am having the same problem with images over 20MB Can anyone help us?
2 Posts No Rating |
Yes I believe mine was over 20 mb as well. Please help!
20mb? wow that's way too big for a single image. I average 300kb per image on a decent high qualiy settings. Maybe your rendered image is there... just make sure you are looking at the right format... (I'll suggest using the "exlore" to look for your images just incase you save it on a different format) You never know.
"If you tell the truth, you don't have to remember anything" |
What version of Revit are you using?
2 Posts No Rating |
Revit 10 the settings were for a 6" x 4" stright image 600 DPI high Quality settings exterior sun only, no clouds with the sun in the summer solstice. the Uncompressed image size is 37.1 Thanks
Edited on: Thu, Nov 19, 2009 at 11:54:01 AM
I never had this problem before last weekend. I too was attempting to export 600 dpi images (72 MB) and could not. My workaround was something like, take a screencapture with Jing. Not an ideal solution, but better than losing my rendering. Could not save to project either. Scratching my head. I'll ask another guy in the office who might know something about it.
Wooden floor render problem - how to change direction of flooring??????? |
Fri, Mar 18, 2011 at 2:42:49 PM
Exporting & Saving Renders |
Tue, Aug 20, 2013 at 9:27:49 PM
Render - Lumincent Image - Interior Scene |
Mon, May 9, 2011 at 3:59:33 PM
can't render background image at 300DPI |
Mon, Oct 11, 2010 at 11:26:56 AM
Exporting Renders in Revit 2012 |
Wed, Oct 3, 2012 at 2:03:16 PM
Members: | 2005596 | Objects: | 22910 | Forum Posts: | 152188 | Job Listings: | 3 |
