76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> Yet another Shared Parameter Question
I have added some parameters to a crown moulding family and for some reason, when it is loaded into the project, those parameters do not show up. They are Instance type Family Parameters. I need to have the option of adding data like material type, finish type, install date, etc. Any clues to what I did wrong?
a little more info. I also can't seem to make the parameters shared. The option is greyed out. I need to make them shared so they will show up on a schedule.
You need these parameters in a shared parameter file before you create them in the family. You can read about this in your help.
1 Posts No Rating |
It sounds like you are creating a profile family, are you creating the molding with a profile family within your project? If you are, then the parameters must be type parameters as you will not get a dialouge box for instance parameters for profiles. Also profiles cannot have shared parameters as their use dictates that any shared parameters would be useless. You can make shared parameters within a family by editing the shared parameters text file when creating your new parameter as long as the familiy is not a profile family. Hope I have answered your question.
Cannot Locate SHARED PARAMETER FILE! |
Tue, Oct 7, 2008 at 3:16:48 PM
Getting Floor thickness in to shared parameter |
Tue, Jun 19, 2012 at 7:30:19 AM
Shared Material Between Families |
Mon, Aug 31, 2015 at 11:21:40 AM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
Instance Shared Parameter?? |
Fri, Jul 11, 2014 at 2:49:26 PM
Members: | 2000315 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
