52 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Orient By plan
Hi there As someone know the 2010 command for the 2009 View – Orient – By plane command? nirim
Right click on the view cube. If you have it switched off, you can switch on by clicking on 'User interface' on the view menu. You can create a shortcut to do that if you prefer the view cube switched off. Orient - by plane is on the little down arrow on the steering wheel.
Edited on: Fri, Sep 11, 2009 at 1:09:04 PM
tim123 Many thanks. nirim
Orient section cut to object |
Sun, Jan 31, 2010 at 8:28:59 AM
Orient a view perpendicular to a work plane |
Thu, Dec 17, 2009 at 11:52:39 PM
Orienting plan regions |
Thu, Sep 3, 2015 at 2:59:30 PM
2D Axonometric |
Mon, May 17, 2010 at 11:54:18 AM
Orient a light to an angle Mass Plane in Revit 2010 |
Tue, Nov 24, 2009 at 10:32:25 AM
Members: | 2000412 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
