56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall Intersection Cleanliness
Tue, Aug 9, 2005 at 10:26:22 PM | Wall Intersection Cleanliness
arccodex1
3 Stars: 1 Votes
Is it just me or is wall cleanliness a difficult thing to achieve when you have new, existing, and demo'd walls, doors and windows overlapping? The EDIT WALL JOINS tool helps a little. I guess achieving cleanliness is a bit of a skill. Can anyone think of any other tools that help?
Wed, Aug 10, 2005 at 1:20:08 AM | RE: Wall Intersection Cleanliness
eldados
eldados Avatar
4.5 Stars: 8 Votes
would help to see an imge... if the clean wall joints does not work as good, try to drag the walls end points. also, in some tricky situations sometimes I pick disallow joints, drag the wall to where i want and if needed use the linework tool to hide lines...
Dimensioning to a "Point" at wall intersection in 2008
Wed, Jan 30, 2008 at 9:41:11 AM
Wall intersection issue
Thu, Nov 26, 2015 at 9:26:18 AM
problem with wall intersection
Thu, Sep 7, 2006 at 12:18:32 AM
Joining Cavity wall with separating wall
Mon, Jul 14, 2014 at 9:12:31 PM
Wall Floor Intersection Cleanup
Thu, May 4, 2006 at 12:06:45 PM
Page generation time: 0.8807
