59 Users Online (58 Members):
Forums >> Revit Building >> Technical Support >> Uncompress Walkthrough Codec Problem
Hello.... I just finished the 1650 frames rendered walkthru and i can't open it.... it's giving me a codec problem using WMP. it's an AVI format. I didn't compress it. I simply used "uncompress" now i can't play it.... it's a big file - 3.6 gb. need your help please so i can play it. Thanks!!!!
"If you tell the truth, you don't have to remember anything" |
wow, even if you could open it I doubt it would be a smooth animation. The file is just way to big. I always use these settings: 30fps, Dimensions at about 640x480, Cinepak Codec, key frame every 15 frames. I'm not sure about the codec problem though. Good luck
2011 Revit Architecture Export Walkthrough CODEC |
Tue, May 18, 2010 at 9:43:10 AM
Walkthrough problems in Revit 2012 Win 7 64 bit |
Thu, Sep 29, 2011 at 6:07:53 PM
Walkthrough playback error |
Tue, Feb 24, 2009 at 6:38:10 AM
HOW TO USE AN ALTERNATIVE CODEC IN REVIT 2009 |
Sun, Apr 26, 2009 at 8:38:34 PM
Exporting Walkthrough Trouble |
Thu, Apr 17, 2008 at 8:00:50 AM
Members: | 1997392 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
