Forums >> Revit Building >> Technical Support >> Wall Subcatigories
Tue, Jul 26, 2005 at 11:40:28 AM | Wall Subcatigories
bolandereric
Does anyone know if you can change the subcatigory of a wall. What I am trying to do is put walls in with diffrent line styles in plan view.
Tue, Jul 26, 2005 at 4:47:56 PM | RE: Wall Subcatigories
pepsiqueen
pepsiqueen Avatar
what if you duplicate the wall type and change it
Tue, Jul 26, 2005 at 6:06:22 PM | RE: Wall Subcatigories
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What do you need to change? Generally you should have different wall types setup based on the various types of walls in your project... Have you just used a generic thickness wall? As a general rule i always have the wall structure built in revit exactly the same as it would be in construction. This includes finishes...
Splitting a curtain wall to change the type of wall it is
Thu, Aug 6, 2009 at 12:46:42 AM
create a wall sweep on an angled wall (gable end wall) (2017)
Wed, Aug 3, 2016 at 2:29:53 PM
wall mounted toilet wall error
Wed, May 6, 2009 at 3:41:37 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
Arched Opening in a Curved Wall [ 1 2 ]
Thu, Nov 15, 2012 at 12:32:31 PM
17
Page generation time: 0.7884
