59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Walkthrough in Revit or 3Ds Max (Live TV)
Mon, Jun 15, 2009 at 3:43:33 PM | Walkthrough in Revit or 3Ds Max (Live TV)
Quantifier
Quantifier Avatar
3 Stars: 2 Votes
Does anyone know how to do a Live Video (TV) in a walkthrough? What program and procedure to use? Any help would be appreciated. Thanks! Allan
Tue, Jun 16, 2009 at 12:08:44 PM | Walkthrough in Revit or 3Ds Max (Live TV)
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
I dont quite get what you are saying. You want to render a walkthrough? Or  you want a realtime walkthrough with user control?
Tue, Jun 16, 2009 at 1:05:44 PM | Walkthrough in Revit or 3Ds Max (Live TV)
Quantifier
Quantifier Avatar
3 Stars: 2 Votes
I'm sorry... What I'm trying to find out is what programs are used to do a "live tv" on a rendered walkthrough. I've seen some walkthrough where you can see the TV set having a "live" action on the screen. Also, how do you do a animated door where the door opens during walkthrough - can 3Ds Max do this or is it just a matter of exporting the jpegs with the door in open and closed position in a certain key frames? Thank you.
Tue, Jun 16, 2009 at 1:12:05 PM | Walkthrough in Revit or 3Ds Max (Live TV)
tim123
4 Stars: 19 Votes
You can't do either of those in Revit.  Max is what you need for that.
Tue, Jun 16, 2009 at 1:36:10 PM | Walkthrough in Revit or 3Ds Max (Live TV)
alabaster2513
3.5 Stars: 25 Votes
Yeah you want Max or Cumbustion for sure, maybe both if you are trying to get that elaborate
Tue, Jun 16, 2009 at 1:55:00 PM | Walkthrough in Revit or 3Ds Max (Live TV)
tim123
4 Stars: 19 Votes
I believe that you can map AVI's to objects in Max.
Wed, Jun 17, 2009 at 10:48:27 AM | Walkthrough in Revit or 3Ds Max (Live TV)
Quantifier
Quantifier Avatar
3 Stars: 2 Votes
I did some research on mapping an AVI to an object using 3Ds Max ..... but found not luck at all. But they do have "motion-capture" thigamagigger... but i think that's something to do with bipped or something. Still hoping to find the way to do it. Thanks!!!
Wed, Jun 17, 2009 at 11:44:16 AM | Walkthrough in Revit or 3Ds Max (Live TV)
alabaster2513
3.5 Stars: 25 Votes
the only thing in Max I have ever rendered like that was fire and I had to render a different image in each frame in order to get the fire effect. Combustion is the program you need to do this, it is an advanced video editing software. Once your scene is rendered you add in the video. I think adobe may also have a program similar to this.... uhhh After Effects perhap, I can't remember.
search the help file for Synchronizing an Animated Bitmap with the Scene
Edited on: Wed, Jun 17, 2009 at 11:49:29 AM
Wed, Jun 17, 2009 at 11:53:16 AM | Walkthrough in Revit or 3Ds Max (Live TV)
tim123
4 Stars: 19 Votes
See this link
http://www.max-realms.com/modules/newbbex/viewtopic.php?topic_id=1570&forum=31&keywords=avi+map#forumpost6625
Wed, Jun 17, 2009 at 12:12:26 PM | Walkthrough in Revit or 3Ds Max (Live TV)
alabaster2513
3.5 Stars: 25 Votes
I have tried that before and have not been able to ever get it to work, although i gave up pretty quickly. I think I just ended up with a gray plane
Wed, Jun 17, 2009 at 1:19:56 PM | Walkthrough in Revit or 3Ds Max (Live TV)
#11
Quantifier
Quantifier Avatar
3 Stars: 2 Votes
That's a great link Tim, I'm going to try that when i get i chance and let you know what happen. (probably you guys will beat me to it anyway) .... Alabaster, I will check out the Combustion or Affter effects too - Alabaster, you mentioned "I think I just ended up with a gray plane" maybe you need to apply the UVW like the link says? Let me know. Thanks for all your help guys!!! This is an awesome site for learning!!!
Wed, Jun 17, 2009 at 2:01:09 PM | Walkthrough in Revit or 3Ds Max (Live TV)
#12
Quantifier
Quantifier Avatar
3 Stars: 2 Votes
I just thought I'd share this from "help" about material editor/bitmap....
A bitmap is an image produced by a fixed matrix of colored pixels, like a mosaic. Bitmaps are useful for creating many kinds of materials, from wood grains and wall surfaces to skin and feathers. You can also use an animation or video file instead of a bitmap to create an animated material.
Revit Walkthrough Path/Camera to 3Ds Max
Fri, Aug 7, 2009 at 11:37:26 AM
Best Reference to Rendering Revit Models in 3DS Max
Mon, Oct 31, 2011 at 11:00:38 AM
render my walkthrough in 3DS MAX
Tue, Apr 23, 2013 at 2:07:40 PM
Revit bring into 3ds Max [ 1 2 ]
Sat, Dec 25, 2010 at 6:24:33 PM
17
Intermediate Revit user here looking for advice on 3ds max [ 1 2 ]
Thu, Sep 8, 2011 at 3:41:35 PM
18
Page generation time: 1.6185
