113 Users Online (111 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Stair Issue
Fri, May 8, 2009 at 3:57:40 PM | Stair Issue
rmwilkening
I am trying to draw a set of stairs into a residential revit project, and I have adding numerous amounts of stairs in other projects, but everything I draw the stairs into the plan, it has the stairs flipped in the direction that I need. I know that there is an arrow to flip them, but everytime I click to do this step I get a message stating that the stair faces cannot be generated and then the stairs are deleted? Any suggestions.
 Thanks
Sat, May 9, 2009 at 11:26:55 AM | Stair Issue
tim123
4 Stars: 19 Votes
Mirror or rotate the whole stair?
Sat, May 9, 2009 at 11:38:04 AM | Stair Issue
4 Stars: 201 Votes
What kind of stair are you trying to create??? images....
Sat, May 9, 2009 at 12:24:59 PM | Stair Issue
rmwilkening
Mirror or rotate doesnt work, the same thing happens and it stated that faces cant be created. I am trying to create a single switch back stair that goes up 8 ft.
Sat, May 9, 2009 at 1:58:53 PM | Stair Issue
4 Stars: 201 Votes
I just create the five kind of stairs possible in Revit and create another by boundary and risers, in ALL of them if i click in that arrow, they flip, in ALL of them i can rotate or mirror, so, try to create another one and check if it works, if not put here (upload) that stair and i gonna take a look...
Sun, May 10, 2009 at 11:33:49 PM | Stair Issue
rmwilkening
i tried to build it in the model and outside of it and both times it says that the faces could not be generated when i try to get the stair in the model the corrext orientation. I will attach the file. The stairs go in the bottom right corner.  I also had a question about rendering rendering sketchup components. When you render the image the components appear white, is there anyway to change that.  Thanks for your help.
Mon, May 11, 2009 at 3:30:24 AM | Stair Issue
4 Stars: 201 Votes
1) You forgot to attach the file
2) About the render of sketchup objects there are here in the forum hundred of post about this issue, try to find them...
Edited on: Mon, May 11, 2009 at 3:33:48 AM
Mon, May 11, 2009 at 8:51:59 AM | Stair Issue
rmwilkening
How can I make my file smaller to fit the 2mb max limit when the file is currently 9.8mb?
Mon, May 11, 2009 at 9:06:37 AM | Stair Issue
4 Stars: 201 Votes
Create a copy of that file, then delete all of you don't need, then purge the file.... if you need try winzip or winrar...
Mon, May 11, 2009 at 10:10:43 AM | Stair Issue
rmwilkening
Ok hopoefully the file is attached this time. Thanks for refer me to the threads for sketchup rendering help.
Mon, May 11, 2009 at 10:53:28 AM | Stair Issue
#11
tim123
4 Stars: 19 Votes
There is no stair in the file that you uploaded, but I have no problem creating the stair or flipping it.
Mon, May 11, 2009 at 11:03:15 AM | Stair Issue
#12
rmwilkening
the stair needs to be going up in the opposite direction than you have it. and when i try to flip it states that stair faces cannot be generated. Do you have that problem??
Mon, May 11, 2009 at 11:21:42 AM | Stair Issue
#13
tim123
4 Stars: 19 Votes
No, I could flip it - I've closed the file already, but I did need to adjust some of the stair settings (max riser height, width) to have the same amount as shown in the CAD drawing.
Mon, May 11, 2009 at 11:41:21 AM | Stair Issue
#14
rmwilkening
I just tried to add the stairs in again, and I am getting the same error even after I changed the riser height. When I go to flip it it still states that the faces cannot be generated. Is there something that I am doing incorrectly? I have attached a file witht the stair in place.
Mon, May 11, 2009 at 12:00:58 PM | Stair Issue
#15
tim123
4 Stars: 19 Votes
I'm not sure what the problem is - I have no trouble creating it, although the file that you've just uploaded shows risers to be 7 feet high - I changed that to 9 inches and it worked.
Assembled Stair Material Issue
Thu, Feb 13, 2014 at 7:16:59 AM
Curved stair and railing issue
Tue, Oct 4, 2016 at 1:32:22 PM
dual entry stair
Sun, May 29, 2011 at 11:05:33 AM
Stair Winder issue
Thu, Feb 9, 2012 at 5:31:14 PM
11
Stair questions... Revit 2010
Wed, Jul 13, 2011 at 12:23:39 PM
Page generation time: 0.5065
