139 Users Online (138 Members):
Forums >> Revit Structure >> Technical Support >> Missing surface patterns in 3D
20 Posts No Rating |
"Also - makes sure surface patterns are on in VG. " One of the first things I looked for was a toggle for this in visibility/graphics because that's typically the solution, but I don't see anything for surface pattern in VG...
I asked if you looked at VG .. you must not have. The surface patterns of walls is set to hidden. Turn them to visible ... done!
Yeah.... it's hidden in VG..... WWhub was right at the first time...
" I asked if you looked at VG .. you must not have. The surface patterns of walls is set to hidden. Turn them to visible ... done! " Eureka! I knew it would be the most simple thing... I had looked several times over and just completely overlooked that visibility toggle. My cube mate just did a facepalm when I told him the solution. See attached image for what we all look like at this point in time. Thanks so much to everyone!
Yeah...simple solution....
Surface Patterns in Perspective |
Fri, Jan 27, 2012 at 7:04:34 AM
Surface Patterns |
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility |
Tue, Nov 14, 2006 at 6:37:24 PM
materail surface patterns |
Fri, Jun 13, 2008 at 8:06:11 AM
No Surface Patterns in Perspective |
Thu, Feb 1, 2007 at 4:55:53 PM
Members: | 1995273 | Objects: | 22882 | Forum Posts: | 152183 | Job Listings: | 3 |
