95 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Missing surface patterns in 3D
Fri, Apr 10, 2009 at 10:40:17 AM | Missing surface patterns in 3D
dlewy
I think the attached picture says it all, but when in 3D view no surface patterns are displaying. They display fine in section and the cut pattern shows fine in plan, but nothing in 3D.
Our firm is fairly new to Revit so we don't know what we're doing wrong and searching endless documents and websites resulted no solution.
 Any help?
We have the surface material set as a model pattern and not drafting.
Fri, Apr 10, 2009 at 10:46:06 AM | Missing surface patterns in 3D
dlewy
Whoops, seems there was an error attaching the image
Fri, Apr 10, 2009 at 10:51:04 AM | Missing surface patterns in 3D
4 Stars: 201 Votes
Are you sure you put in the "Surface Pattern" a pattern???? MODEL PATTERN..
Fri, Apr 10, 2009 at 11:09:56 AM | Typhoon
dlewy
Quoting Typhoon from 2009-04-10 10:51:04
" Are you sure you put in the "Surface Pattern" a pattern???? MODEL PATTERN.."
This is what I have it set as (See attached)
Fri, Apr 10, 2009 at 11:31:24 AM | Missing surface patterns in 3D
3.5 Stars: 390 Votes
We can not tell from the screen shot if the pattern you are using is a drafting or a model pattern.    If you want the pattern to show up in all non-rendered views, it must be a model pattern.  Otherwise it will only show in elevations and you will not be able to adjust it.
Fri, Apr 10, 2009 at 11:34:32 AM | Missing surface patterns in 3D
afc4
3 Stars: 3 Votes
Is the wall backwards? ( drawn in the wrong direction) Check to see if the other side has the pattern. But if the wall just has one material check to see if Surface pattern is a "model" or "drafting" pattern. If its model try creating another wall to see it that works.
Fri, Apr 10, 2009 at 11:40:41 AM | Missing surface patterns in 3D
dlewy
Here's a screenshot showing that model is indeed checked.
 The wall is not backwards and the pattern isn't showing up on any sides. Also tried drawing a new one and got the same problem.
Fri, Apr 10, 2009 at 11:44:47 AM | Missing surface patterns in 3D
4 Stars: 201 Votes
Hummmm, can you please post here that simple wall to download so we can take a look????
Fri, Apr 10, 2009 at 12:05:29 PM | Missing surface patterns in 3D
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi dlewy...I think that you duplicated one wall to assign that pattern to the duplicated wall, but just for curiosity, are you sure you changed that wall to the new one with the assigned pattern? I repeat, just for curiosity .....
Edited on: Fri, Apr 10, 2009 at 12:07:58 PM
Fri, Apr 10, 2009 at 12:07:02 PM | Typhoon
dlewy
Quoting Typhoon from 2009-04-10 11:44:47
" Hummmm, can you please post here that simple wall to download so we can take a look????"
Ok, uploaded. We used the generic Revit supplied wall masonry wall. In the sample I adjusted the settings identical to how we have it in our other file so maybe you'll catch something we're not.
Fri, Apr 10, 2009 at 12:09:29 PM | Missing surface patterns in 3D
erland73
erland73 Avatar
4.5 Stars: 85 Votes
And the file????
Fri, Apr 10, 2009 at 12:14:07 PM | erland73
dlewy
Quoting erland73 from 2009-04-10 12:09:29
"And the file????"
Sorry guys, long week and new to the forum software. Is there a way to include the file in my post (file attachments are limited to 2MB and my file is a touch over 4MB)
I uploaded it and it's accessible through my profile either way
Fri, Apr 10, 2009 at 12:17:13 PM | Missing surface patterns in 3D
#13
4 Stars: 201 Votes
create a copy then go to the "file>purge Unused", save and see if the new file have less than 2Mb, if not send me a email (it's in my profile)....
Fri, Apr 10, 2009 at 12:19:51 PM | Missing surface patterns in 3D
#14
I bet you painted this wall.... grab your paint bucket and paint it with defdault and see what happens...
Also - makes sure surface patterns are on in VG.
Fri, Apr 10, 2009 at 12:23:16 PM | Typhoon
#15
dlewy
Quoting Typhoon from 2009-04-10 12:17:13
" create a copy then go to the "file>purge Unused", save and see if the new file have less than 2Mb, if not send me a email (it's in my profile)...."
Oops, got it down below the limit the second after I emailed it to you lol
 See attached for everyone else
Surface Patterns in Perspective
Fri, Jan 27, 2012 at 7:04:34 AM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
Existing Phase Surface Patterns visibility
Tue, Nov 14, 2006 at 6:37:24 PM
materail surface patterns
Fri, Jun 13, 2008 at 8:06:11 AM
No Surface Patterns in Perspective
Thu, Feb 1, 2007 at 4:55:53 PM
Page generation time: 3.1459
