155 Users Online (154 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> perforated metal or Expanded sheet metal
Thu, Dec 22, 2011 at 1:51:39 PM | perforated metal or Expanded sheet metal
#16
3.5 Stars: 391 Votes
Just create the door with a flat panel where the mesh is.  Assign a mesh material to the panel.
Thu, Feb 16, 2012 at 5:04:07 AM | perforated metal or Expanded sheet metal
#17
danielo
Thanks for those suggestions guys, I'll give them a try as I've got the same issue.
Cadisch MDA
Fri, Oct 26, 2012 at 6:38:33 AM | perforated metal or Expanded sheet metal
#18
eduardbucsa
you guys are geniuses. Exactly what i was looking for!  Thanks!!! Smile
Thu, Feb 7, 2013 at 5:01:37 AM | perforated metal or Expanded sheet metal
#19
aozarski
I am using Revit 2013 and I aissgned a metal material to my panel and added hexagonal cutouts, but they are huge.  I am trying to reduce the size (playing with size and center spacing), but I cannot get it to make them around a 1/4".  Can anyone help with this?
Thu, Feb 7, 2013 at 12:49:49 PM | perforated metal or Expanded sheet metal
#20
4 Stars: 201 Votes
Same answer....
Mon, Feb 11, 2013 at 3:50:59 AM | perforated metal or Expanded sheet metal
#21
aozarski
Thanks.  But I am not able to get the openings and the width of the metal between the openings small enough.  I would like the openings to be about 1/4" with 9/32" staggered centers (see attached image).  When I put in these sizes it doesn't work.  The image that you sent still looks too big, although it is difficult to tell without any reference scale.
Mon, Feb 11, 2013 at 4:01:33 AM | perforated metal or Expanded sheet metal
#22
4 Stars: 201 Votes
You'll have to use the WHOLE image and not only one "hole" size, I don't work in Imperial, only metric system so, create the image with 25.5 cm x 16 cm (I think that's the correct size of that image) and test it.
Mon, Feb 11, 2013 at 4:39:09 AM | perforated metal or Expanded sheet metal
#23
aozarski
Thanks!  That worked.  Under cutouts in the material editor I used a custom image and then scaled it to the size I need.  I really appreciate the help.
Thu, Feb 11, 2016 at 10:32:49 AM | perforated metal or Expanded sheet metal
#24
cwo1187
Hi All,
I am using Revit 2016 and I can't find a material in any library that has perforations. Am I missing something? Every other forum suggests just making a mesh myself, but it would be much easier and quicker if I could just select one from the materials library.
Thank you!
Thu, Feb 11, 2016 at 4:06:37 PM | perforated metal or Expanded sheet metal
#25
Create your own - read this in your help.
Mon, Mar 5, 2018 at 5:55:54 PM | perforated metal or Expanded sheet metal
#26
riddhitrumble
I have revit 2018, it has come with very few materials. Like it does not have those material finishes under metal like shown below by Typhoon. If materials i see in manage tab, are all the materials i have.
I have been trying to find material libraries, which I had thought would be very easy but hasn't been. Can anybody can guide me how to fill up my libray?
I am right now looking for some nice perforated metal options.
Perforated Metal Panels
Mon, Apr 26, 2010 at 11:46:49 AM
Perforated metal panel
Wed, Oct 30, 2013 at 7:36:33 AM
Perforated metal screen?
Fri, Nov 12, 2010 at 9:21:25 AM
Question for metal cladding sheet as curtain panel attached to slopped roof
Sat, Jul 24, 2021 at 8:17:45 AM
Perforated Metal Panel-Fill Patterns
Thu, Sep 14, 2006 at 10:14:35 AM
Page generation time: 0.4800
