72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Newbie arched top wall question
15 Posts No Rating |
I have searched but have not been able to find a way to create an arched top for a wall and apply a sweep or banding to the top. I realize this is probably simple, but even the Revit help does not explain it. Thanks in advance. Jim
To make a wall have an arched top you need to select the wall and edit the profile of it. this is best done in an elevation or section view. and as far as adding a sweep to it you can use massing for that.
Don't use a mass for this - create an in-place family. You can choose the face of your wall for your work plane.
Thanks for the edit profile, it worked like a charm. This is the wall I want to add a cornice to. How do I create the arched cornice for this? Thanks again for your help.
Like WWhub said, don't use mass to do that, use "Create-in-Place"- chose the category you want, then "solid sweep"...
I was able to make it with that create in place creating a sweep. Thanks very much for your help.
Arched Curtain Wall Arched Mullions |
Wed, Jan 22, 2020 at 2:13:08 AM
Dividing Surface on arched wall |
Tue, Nov 16, 2010 at 3:57:16 PM
help with arched opening |
Mon, Dec 8, 2008 at 6:41:45 AM
Arched Windows |
Thu, May 7, 2009 at 11:59:27 AM
arched curtain wall |
Mon, Feb 26, 2007 at 10:17:47 AM
Members: | 1998310 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
