72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Demo brick on brick/cmu cavity wall
10 Posts No Rating |
Is it possible to only demo the brick or a portion of the brick on a brick/cmu cavity wall? I've only been able to show the entire wall as demo. I'm using Revit Arch 2009. Thanks!
split the wall so that you can make a section that you wish to demo. Or create an opening and add in the same wall type in the open space, and demo that piece.
Sorry masterbrewer, the way I have achieved this in the past is to create a wall that is brick only and embed it into the brick over cmu, then demo the brick, thus leaving the existing cmu behind. I only needed to do this in areas where I was keeping some brick.
CMU + brick wall- brick is NOT bearing |
Tue, Dec 22, 2009 at 3:16:30 PM
Hello Newbie here, brick on brick on cmu wall type doesn't show up |
Thu, Jan 27, 2011 at 1:06:15 PM
Demo issues? |
Mon, Oct 12, 2009 at 1:30:38 PM
Brick wrap around the top and sides of CMU wall |
Tue, May 10, 2016 at 10:04:28 AM
Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s |
Wed, Apr 8, 2009 at 5:08:39 PM
Members: | 2000679 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
