45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Remodeling Issues
Thu, Jun 30, 2005 at 4:39:14 PM | Remodeling Issues
rdav
Most of my work involves remodeling, so instead of drawing a new building from scratch I need to draw buildings where I need to represent existing measurements, which tie to wall interiors and exteriors rather than wall centers. Is there a simple way to do this? Are there tips and approaches that make revit as fast and easy to draw an existing building as it is to create a new one? Also, I have used another product for years that has the ability to establish reference points and lines that can be protected from inadvertent movement or deletion. Does Revit have this capability? TIA, Robert.
Thu, Jun 30, 2005 at 5:28:00 PM | RE: Remodeling Issues
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Certainly can... When you've sketched out the walls orinally in revit just dimension to there faces (change default from centrelines to faces) then lock the dimensions or pin the wall once you have it in place... HTH.
Thu, Jun 30, 2005 at 5:53:47 PM | RE: Remodeling Issues
rdav
That helps. Thanks! - Robert Post edited on 2005-06-30 18:05:15
New Wall Not Showing Properly
Fri, Nov 18, 2011 at 12:14:42 AM
Manage Large Job and Printing Issues
Tue, Feb 19, 2008 at 5:00:05 PM
How to edit Curtain Wall Grids and remodeling windowall
Tue, Sep 2, 2008 at 2:29:23 PM
Mirror issues, mouse selection issues
Wed, Dec 10, 2014 at 4:14:28 PM
Creating an Alternate Floor Plan(Revit 2009)
Mon, Oct 20, 2008 at 11:18:08 AM
Page generation time: 0.1367
