162 Users Online (161 Members):
Forums >> Revit Building >> Technical Support >> How is this symbolic line linked to a parameter?
83 Posts No Rating |
HiIf you view this family from the Front you'll see two Hidden Face symbolic lines.They're move in relation to the t parameter. They're locked to something but I can't work out what.In Wireframe style there is a face of the sweep, but if I unlock & try to relock to it it fails.I've seen it done before in other families, but with ref planes & dims with parameter labels.I can see any of those here.There are some in the profile but can't work out how they're linked to the symbolic lines.What am I failing to understand? Cheers Dave F.
If you view the front in wire frame view then you can see what they are locked to - the web of the steel section.
Yes, I mentioned wireframe in my OP, but try & select them, try aligning & locking to them? I couldn't. :-( Can you?
The lines may have been done in a section view, since deleted. You can reproduce this by giving the plane on which the lines appear a name, creating a section through the web, draw symbolic lines on the named plane using the select line tool and deleting the section.
For the benfit of others with the same problem, I found the answer at "another" site: I couldn't lock the SL's becauseof the curved fillets.If I cut a section through the straight faces I could lock them!. Dave F.
Vertical bracing symbolic line ??? |
Tue, Jun 4, 2013 at 7:33:50 AM
Symbolic lines |
Tue, Dec 26, 2006 at 2:24:22 AM
Symbolic lines in elevation |
Thu, Jan 10, 2008 at 7:12:53 PM
position of beam symbolic line on plan |
Wed, May 16, 2012 at 4:11:30 PM
Symbolic Line to a Curved Face |
Mon, Nov 13, 2006 at 9:33:10 PM
Members: | 1998605 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
