63 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> Stair and Door question?
23 Posts No Rating |
I am having some trouble creating a simple stairs. Basically its like an L shaped stairs with a step up to a landing and it turns up and the rest of the stairs is straight. Here is an image so you get a better idea.
The stairs I am trying to creat is in red. How would I create this type of stairs?
Also, see the doors on the right inside the red circle? I need to show the swings at 45 degrees so they dont bump into each other like that. How could I change that?
Thanks in advance!
Post edited on 2005-06-29 01:17:54
Stair:
Just start up the stair tool and draw the risers using the riser tool and draw both the boundaries for the stair (a stair can only have two boundaries), the riser lines will span between the two boundaries...
Door:
You we need to be using a door with an adjustable swing parameter. This is something all the swing doors in our office have but it would really depend on the family you are using.
Thank you I will try that.
Curved Stair Question |
Mon, May 7, 2007 at 2:10:41 PM
Door Swing Question |
Mon, Oct 22, 2012 at 3:51:32 PM
12
DOOR TAG QUESTION |
Fri, Mar 1, 2013 at 7:32:19 AM
Door parameters not scheduling or tagging in double door. |
Mon, Sep 26, 2011 at 3:29:50 PM
Monolithic Stair Question |
Thu, May 26, 2011 at 7:14:39 AM
Members: | 1996820 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
