59 Users Online (58 Members):
Forums >> Revit Systems >> Technical Support >> Revit 2009 MEP Newbie - Can place anything on walls not created by Autodesk
53 Posts No Rating |
I am a Newbie to Revit MEP 2009 and hating every minute of it. That said, I have linked in an Architects Revit plan into my new project. When I try to place a piece of equipment like a sink or thermostat on a wall it wont let me do it. If the wall was drawn on the actual sheet it has no probelms. What am I doing wrong? KHeinz
If your elements are hosted, then the host (or a copy of it) has to reside in your model. Copy monitot the wall and your items will then work.
23 Posts No Rating |
Clarification: You can host to the face of a linked .rvt file, but not to the actual family within the linked file, ie. walls, ceilings, etc. Change your fixture to be a face based family or, as mentioned previously, copy/monitor the elements you need to use as hosts.
Revit MEP 2008 Newbie! |
Mon, Oct 1, 2007 at 10:00:09 AM
What Revit version to use when creating families for SEEK? |
Thu, Apr 17, 2014 at 9:37:02 AM
Revit Structure to MEP |
Tue, Feb 24, 2009 at 7:19:48 AM
AutoDesk Buidling Systems - MEP |
Thu, Sep 21, 2006 at 4:28:54 PM
Revit MEP or AutoCad MEP |
Fri, Oct 14, 2011 at 8:21:49 AM
Members: | 1996892 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
