91 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Walkthrough playback error
Tue, Feb 24, 2009 at 2:37:30 AM | Walkthrough playback error
andyp
Hi, i Just created a rendered walkthrough, when i try play it back on media player i get the following error message -Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.the file is 2.2gb and an uncompressed avi, Ive used this setting before without problem, although the filesize has never been quite this large before. Anybody got any ideas how i can get this video file playing, its taken a few days to render so really dont want to try again just to get the same problem occuring?
Tue, Feb 24, 2009 at 4:58:15 AM | Walkthrough playback error
4 Stars: 201 Votes
Well, it's look like you don't have the rights codecs, did you try to open the file with other player???
Tue, Feb 24, 2009 at 6:20:20 AM | Walkthrough playback error
andyp
Thanks for the reply. After playing round abit i managed to open it and compress it with a freeware program i found on the net called VirtualDub. The compressed file works in media player so im not sure what was going on.
Cheers Andy
Tue, Feb 24, 2009 at 6:38:10 AM | Walkthrough playback error
qthdad
5 Stars: 2 Votes
I had that exact same problem. I think it has something to do with file size. My test walkthroughs worked and I was able to playback using WMP. Then I went to do the actual walkthrough using the same settings, and like you, I let it run for days... The file was HUGE! 1.8GB and would not play in any sort of player. I downloaded and installed Windows XP codec package + various other codec package, nothing worked.
Ultimately, I had to do redo the walkthrough. The 2nd time around, I heeded some of the others' advise and selected JPG output. Then used VirtualDub to compile the frames. As long as you have the JPGs, you're safe. No more fear of having a corrupt AVI output.
There are some big advantages to this.
1. You have rendered JPGs to use for other purposes.
2. Render time seemed faster. I think because Revit doesn't have to encode on the fly.
3. I was running Revit on a dual quad-core Xeon workstation and was able to run two sessions of Revit. I made a copy of the model and set one session to render frames 1-300, and the other to render frames 301-end.
Why I ran two sessions? Because a session of Revit only used half the CPU processing available. Two sessions allowed me to fully utilitize the hardware resources. That is, of course, if you have enough RAM. You could also render the 2nd session or additional sessions if you have other computers and licenses available.
NOTE: VirtualDub is sweet. You pick the first frame and it auto-detects the rest. But, from my limited experience with VirtualDub, I had to compile two AVIs and use VirtualDub to append one to the other. Works fine. I didn't find a way to have VirtualDub append two sets of JPG.
You can also look at your render settings and reduce them to get faster rendering. Once compiled into AVI, most of the images will become a "blur" anyway. So experiment with the settings.
Walkthrough won't playback, what codecs are required?
Tue, May 20, 2008 at 10:10:05 AM
Rendered Walkthrough
Thu, Jun 7, 2007 at 7:39:51 AM
walkthrough rendering frame counter?
Thu, Aug 20, 2009 at 10:50:49 AM
walkthrough questions
Mon, Mar 25, 2013 at 2:44:09 PM
Exporting Walkthrough Trouble
Thu, Apr 17, 2008 at 8:00:50 AM
Page generation time: 0.4027
