33 Users Online (32 Members):
Forums >> Revit Building >> Technical Support >> Cove lighting
1 Posts No Rating |
I am trying to put in cove lighting in my space for rendering purposes, I am having a hard time doing this and getting the light source to project the light the right way. Has anyone done this? or any ideas? Thanks!
Cove lighting is hard to do. You need to have your lights made correctly and you have to look at your reflective surfaces.
5 Posts No Rating |
I am having similar problems. I have a linear light source but when I do the render it shows it as coming from a single point. I attached a pick of the rendering. Any ideas on how to correct this problem?
23 Posts No Rating |
YoKanski It is hard to tell without seeing the fixture, but one possibility is that the light source definition in the fixture family is set to the incorrect type. Try opening the fixture in the family editor, selecting the light source, and checking the source definition.
5 Posts No Rating |
It is Currently a linear light source. Is there another type it should be?
5 Posts No Rating |
Found a slolution to this on AutoDesk's Site. Click Here or see below. - In the Rendering dialog box, select Edit from the Settings drop-down menu.
- Select the Enable Soft Shadows dialog box.
chose to use a photometric web when the light source is selected. Next, go to the family properties and then to photometry change the emit box to the correct dimension and make sure that show emit light box is checked. Also, what version of Revit are you using '09 or an earlier version? This will greatly effect your light renderings as there is a new rendering engine (mental ray WAY better than accurender) in 2009.
cove lighting? |
Wed, Dec 7, 2011 at 2:23:00 PM
How to create a twisted beam of light? |
Sat, Sep 17, 2016 at 11:18:31 AM
How do I create a sweep with a light source? |
Mon, Nov 17, 2008 at 1:33:08 PM
Editing Wall Profile in Plan View |
Thu, Jan 8, 2015 at 7:03:13 AM
interior lighting for exterior rendering [ 1 2 ] |
Thu, Feb 11, 2016 at 2:03:04 PM
16
Members: | 1994396 | Objects: | 22882 | Forum Posts: | 152185 | Job Listings: | 3 |
