78 Users Online (76 Members):
Forums >> Revit Building >> Technical Support >> Room Elevations - Side walls not Printing???
24 Posts No Rating |
As a standard I have never shown the actual wall thickness on room elevations, and still do not want to. Basically i just want to see a line to each side of elevation ... if there is a wall there. I trim my room layout view to touch edge of the wall. On sheet they all appear to have a line to at edge of the wall. I do not want to have to show my crop box as quite often it just doesnt work depending on the room layout ... so i always want to hide it. When i print most of the walls show, but a lot do not. Is this a common problem. Am i doing something wrong? Or do I just have to draw lines to edges of room. Thanks.///
A couple of choices: - Add a line ... I hate this.
- Pull you elevation grip just beyond the edge of the wall ...What I do
- Turn on view crop window and print with the "print the view crop window " selected.
hmmm very frustrating ... i thought it might be a case. sounds like no.2 is a way to go. while on the subject ... any suggestion on how to best stretch the cop view by a set distance. say 2mm into the wall, everytime...to keep things consistant. anyways, thanks in advance jakub c
No idea how - Hope someonelse can tell us - I think AutoDESK should fix this one.
Phasing is interfering with Room Area/Tags (I think) |
Wed, Sep 28, 2016 at 1:15:48 PM
Printing Shaded Elevations to PDF |
Wed, Oct 19, 2011 at 11:23:07 PM
Printing issues - elevations |
Sat, Jun 6, 2009 at 5:15:59 AM
Please Help - How to get Level Tags on same side of all elevations?? |
Thu, Jan 3, 2013 at 2:14:19 PM
Room Tags and Detached Walls |
Tue, Sep 12, 2006 at 12:00:07 AM
Members: | 1998323 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
