70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Building Section callout not showing in plan views
Tue, Feb 3, 2009 at 4:11:44 PM | Building Section callout not showing in plan views
craigl
I created a building section on one of my plan views, but it is not showing up on my other plans.  I have many other sections with no problems (as far as callouts).  I checked my visibilities and still nothing.
Tue, Feb 3, 2009 at 5:25:36 PM | Building Section callout not showing in plan views
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I had this happen to me once turned out that the scale was small on some of my plans, sections do not show unless the plan is larger or you adjust the parameters of the section marker
Wed, Feb 4, 2009 at 8:25:58 AM | Building Section callout not showing in plan views
craigl
Thanks, mbsteve, that did it.
Thu, Aug 12, 2010 at 9:34:47 AM | Building Section callout not showing in plan views
ashevilleARCH
Replying to an old thread here- incase anyone else finds it in search of an answer.
It turns out that if you create a section in a 1/4" plan, it automatically sets it to "hide at scales courser than 1/4" (in the element properties).  It will not show up in 1/8" plans (or anything smaller than 1/4"Winking unless you change this parameter.
Thu, Apr 28, 2011 at 2:04:46 PM | Building Section callout not showing in plan views
db
ok, i give....
how do you change this parameter?
Thu, Apr 28, 2011 at 2:12:02 PM | Building Section callout not showing in plan views
craigl
It is in the properties dialog of the view.  Under the "Graphics" section is  a parameter called "Hide at scales coarser than".
Thu, Apr 28, 2011 at 2:12:47 PM | Building Section callout not showing in plan views
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
when you have the section selected in a view where you can see it, go over in the properties bar, in the graphics section right below "graphics display options"  there's a field called "Hide as scales coarser than"  and you can set that however you like.
Fri, Mar 11, 2016 at 2:21:39 PM | Building Section callout not showing in plan views
sgray05
Understand that I am responding to a 5 year old thread, but it is applicable.
I am having issues with my section tags. They were placed in a 1/4" scale plan. I learned (thank you) that the contraint of "hide at scales corser than" was set to 1/4" scale. and made the adjsutment.
I am trying to get these to show on my overall plan which is 1/8". When I toggle to hidden items, I can see them, but the option to unhide is not available (grayed out)
Can some one pelase help. Thanks
Fri, Mar 11, 2016 at 3:18:03 PM | Building Section callout not showing in plan views
itsmyalterego
4 Stars: 16 Votes
And you set the sections to "hide at scales coarser than 1/8"? If they're set at 1/4, they'll be hidden in your 1/8 plan.
Fri, Mar 11, 2016 at 3:32:04 PM | Building Section callout not showing in plan views
sgray05
Thanks for your reply.
Yes. I adjusted the Course level to 1/8"
They will now show up but are hidden and will not give me the option to unhide.
I read something about the size of the tag, but don't know if this applies?
Fri, Mar 11, 2016 at 3:41:54 PM | Building Section callout not showing in plan views
#11
itsmyalterego
4 Stars: 16 Votes
How much work do you have in the graphics of your overall plan...? Try this... Go to view--view templates--apply view template--(pick a default template)--apply properties--OK. In my experience views can get legitimately glitchy. See if this brings things back.
Building section callout visibility in intersecting views
Mon, Jun 16, 2008 at 12:40:58 PM
callout annotation in section w/ coresponding section anno in plan
Mon, Sep 24, 2007 at 1:33:19 PM
Building Section and Detail Section Callouts
Mon, Aug 7, 2017 at 5:22:41 PM
CALLOUT VIEWS . . .NOT SHOWING UP?
Wed, Aug 10, 2011 at 1:16:06 PM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Page generation time: 1.0743
