70 Users Online (65 Members):
Forums >> Revit Structure >> Technical Support >> Aligning Beams to Slope Reference Plane
10 Posts No Rating |
I have created a reference plane that depicts the slope of my roof. I cut a section and aligned the top of one of my beams with the refernce plane and it worked perfectly. The joist attached to it rotated on the slope. Now I tried to do the next beam and it will not align. I do not get an error just nothing happens. How do I "unlock" this member? I tried editting work plane but didn't work. When i click on the beam that already aligned, i see a unlocked pad lock. When i click on the other beam, no pad lock at all shows up. What am i missing? Thanks, in advance
Figured it out! Right Click, Detach From Plane, Its Magic!
Aligning top of column to top of beams that are set out by bottom of steel |
Thu, Dec 12, 2013 at 12:35:41 PM
Floor or Roof on Sloped Reference Plane |
Tue, Nov 6, 2012 at 8:07:07 AM
Change the slope of beams |
Fri, May 10, 2013 at 1:12:00 PM
reference plane as level |
Thu, Apr 20, 2006 at 1:06:07 PM
Vertical Girder when modeled on sloping reference plane |
Fri, Sep 19, 2008 at 8:09:03 AM
Members: | 2002667 | Objects: | 22887 | Forum Posts: | 152184 | Job Listings: | 3 |
