151 Users Online (150 Members):
Forums >> Revit Building >> Technical Support >> Problem with 3D views
24 Posts No Rating |
quite often when i play around too much in my 3d view, and esspecially seems to happen when i use the section box in 3d the view goes a bit crazy. Hope you know what i mean. walls and models become see through (even though im in shade mode) and model becomes unreadable. I tried reopening the views, restarting revit but the only thing that seems to fix the problem is to delete the view and create it again ... which 1. is not a quick fix and 2. will cause to loose view settings, graphic overrights etc. Im thinking there's gotta be a better way of doing this. Anyone? ... thanks
This issue was report several times here in the forum, there are some problems with Revit and Graphics card... That's the best way to solve the problem until now.....
Problem with views in revit 2011 |
Sat, Jul 10, 2010 at 11:53:40 AM
Referenced views floating in space |
Thu, Oct 22, 2015 at 2:43:48 PM
Elevation Views on Sheets |
Tue, Dec 21, 2004 at 5:54:38 PM
HELP! ALL of my plan views vanished!!!! I've tried creating new views |
Wed, May 9, 2018 at 3:18:43 PM
Highlighting objects problem in 3D |
Thu, Oct 11, 2012 at 2:24:51 AM
Members: | 1998473 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
