62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> assigning top and base levels when inserting columns??
17 Posts No Rating |
the element prop's dialogue box doesn't have any options for top or base level assignments upon architectural column placement. is there a way to define the column placement upon placement? right now i have to place the column and then enter the element prop's dialogue box to define the level assignments
When you place your column you have the option of setting in a top level in the options or an unconnected height. In the element properties you can set in top and bottom offsets.
160 Posts No Rating |
I've attached image showing the elements and type properties dialogue box. I'm pretty sure this is where you're referencing. Might there be something missing in the family creation to make the level assignment drop down box visible??
See attached image. The offsets are in the element properties, but the initial extents are in the toolbar.
Adding Base Level & Top Level to a column tag |
Wed, Mar 13, 2019 at 9:37:05 AM
Columns appearing on levels below. |
Mon, Apr 19, 2010 at 6:33:41 PM
Reasigning associated level/base & top constraints on a masive model |
Thu, Oct 11, 2012 at 12:51:30 PM
Inserting Columns |
Fri, Feb 8, 2008 at 2:05:44 PM
Levels. |
Thu, Feb 11, 2016 at 8:55:59 AM
Members: | 2000220 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
