Forums >> Revit Structure >> Technical Support >> Show model pattern in 3D view
42 Posts No Rating |
Hello! I have searched for information in this forum, but I still can't understand why I can't see the brick pattern of wall in 3D view. I drew "Exterior - Brick on Mtl. Stud" wall and skeched that the pattern given to the surface is model type named "Brick 75x225" , the view setting is set to fine, scale is 1:1 shading with edges. Some have achieved, that the pattern shows not only in elevation views, but it doesnt work with this built in wall type. Can anyone tell me please what setting am I missing! Regards!
Hi, see the video: http://screencast.com/t/pDHOJVtgLvQ
Wow.. this one was cool.. i mean, the Jing thing... I will record my screen, wait a minute please..
Well.. I recorded with CamStudio but cant attach it here... Right now I'm upploading in Jing, I hope it will work out, only jet I dont know where I will get the link to post in here.. The problem is, that the pattern shows only in the elevation views. I can rotate the wall in 3D as I want and look from which side I want, but pattern isnt visible..
Well... here it is http://screencast.com/t/IcnkBhRRtn
Well, very strange, did you ZOOM to the wall in 3D view and check??? can you upload this file with that wall here so i can take a look??
I zoomed.. but nothing..
Something strange is happening with the attaching here.. I attached in previos message file named wall.rvt, but I can't see it attached.. I'll try again..
This simple file is more than 2MB even when commpressed..
The problem was solved, it's in the 3D view in the VG-Walls-Surface patterns are turn Off the "Visible"...
I couldn't find where I can mark this thread as resolved, but it is now. For everyone to know, the problem was that under Visibility graphics - Walls - Projection/Surface Patterns - fill pattern graphics, the visible check box wasnt checked.
Trying to show stone on both elevations and model view |
Tue, Sep 11, 2007 at 2:24:12 PM
How Do I Make My Fill Pattern Show In 3D View |
Tue, Jan 13, 2009 at 2:35:22 PM
Question About Model Pattern |
Tue, Feb 19, 2013 at 2:40:21 PM
Model pattern override |
Wed, Nov 10, 2010 at 3:50:54 PM
Help- floor pattern not showing up in plan, only model?? |
Sat, Apr 1, 2006 at 8:56:46 AM
Members: | 2000182 | Objects: | 22886 | Forum Posts: | 152180 | Job Listings: | 3 |
