43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> copy/monitor 1 MEP model to another
3 Posts No Rating |
I currently am working on a project electrically and another firm is working on it mechanically. I want to cop/monitor thier mechanical devices into my model so I can hook up power to them. I have not found this option yet. Is this possible? furthermore I can't seem to be able to extract the electrical info out of thier schedules so I can schedule the mechanical equipmet. can someone please help me with these issues?
You can link any REVIT model - doesn't matter how it was produced. For your schedule question, use your H E L P with this search linked elements, scheduling
3 Posts No Rating |
I have thier model already linked into mine. The issue is that I can't copy/monitor thier equipment. the only options that I get for copy/monitor is for walls, floors, grids and levels. Revit will not allow me to select the mechanical equipmet.
The only reason to copy/monitor it is if you need to use their items to host your work or if you are going to move them - edit them. So ... are you changing something of theirs or do you want to just see it and schedule it?
3 Posts No Rating |
I want to be able to hook my electrical up to the mechanical equipment. Currently I have the mechanical model linked into mine. I can't put circuits to the mechanical equipment without having the equipment in my model. And I can't see any of the electrical information on thier schedules. So I am kinda stuck.
You are not stuck. First - if you followed the guidelines for the linked model, you will see the schedule. Second - If you can't copy monitor (This may be someting to look on the AUGI site for since I don't have MEP), you can always do it the hard way. - Make sure their model is properly linked. As such, your levels, grids, walls etc are all the sameOpen their model & select all same.
- From a 3D view, select all of their elements using the family menu and select all instances.
- Copy to clipboard
- Open your model in 3D and paste
- Turn off their items in the link.
Copy/Monitor Lights to Revit Architecture 2012 |
Wed, Oct 17, 2012 at 3:05:52 PM
Can't Get Copy Monitor to Work for Grids and Levels |
Fri, Feb 21, 2014 at 4:55:28 PM
Copy/Monitor walls |
Tue, Apr 2, 2013 at 10:14:23 AM
Copy Original Type Not Available in Copy Monitor Options Dialogue |
Fri, Nov 6, 2015 at 2:16:27 PM
Copy/Monitor RCP |
Sat, Oct 10, 2009 at 11:12:47 AM
