65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Dimension problem...
Hi. I have a problem with read convention in dimensions. Some "things" in my project are not parallel (are not set to north-south, are a a little bit kinked???) and when i try to dimension them the dims are upside down. I attached the picture to show exactly what my problem is. Thanks for any replies guys.
Why not turn your whole project so the dimensions in green come back to "vertical". REVIT doesn't like lines slightly off axis and all of yours appear to be. If you rotated it, maybe everything on the left could be orthogonal.
Edited on: Tue, Oct 21, 2008 at 7:09:18 AM
hi you need to dimension the other way around, by this i mean if you selectedat at thetop of the screen then went down, you should start at the bottom of the screen and work up.
Hi. Kingrevit- your way doesn't work, it doesn't matter how i dimension revit always shows my dims upside down. WWHUB- The green dim is paralell but the red ones are not. This is just a little piece of the project, so you can't see all the dims. If you saw the whole project you would noticed I have half of the dims paralell and that half are off axis. So if I turn the whole project I will still have some dimensions that will be off axis. That's the main problem.
Dimension Text Problem |
Fri, Nov 14, 2008 at 9:41:55 PM
Problems importing .dwg details! Text gets scrambled in sneeky ways! Help! |
Thu, May 10, 2007 at 10:06:45 AM
Dimension String Doesn't Equal Overall Dimension |
Wed, May 27, 2009 at 2:33:49 PM
temporary dimension disappearing when converting it to permanent dimension |
Thu, Sep 14, 2017 at 9:48:30 AM
Split View & Dimension Problem |
Tue, Jun 18, 2013 at 10:06:03 AM
Members: | 2000283 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
