55 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Something wrong with visibility
Fri, Oct 17, 2008 at 6:42:26 AM | Something wrong with visibility
Ingarella
Hi!
I'm using Revit Architekture 2009. I have several problems with one file I'm working:
1. when selecting elements (structural column family) they are not appear red, red is only contour of the element.
2. same element in different views appiers in different color. Everithing is ok in family with material, in all options is chosen same color and solid pattern.
3. if i choose "show all" option for phase visibility previous phases doesn't look gray, as it is usual, only wall family elements looks grey, but structural column famaly elements looks same color as when I choose "show new", but a bit lighter.
4. when I go to PANTONE color catalogue all Revit immediatly stops working and I loose all not saved changes.
Problem 1-3 appears only in one file, but problem 4 is general for Revit 2009.
Could you help me with these issues? I would be very greatful
Fri, Oct 17, 2008 at 7:49:19 AM | Something wrong with visibility
Dafpfy
3.5 Stars: 11 Votes
(1.) i may be totaly wrong but are there 2 of the same column in the same place?
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Oct 17, 2008 at 8:18:16 AM | Something wrong with visibility
coreed
coreed Avatar
4 Stars: 16 Votes
are you using the latest Revit Build. here are some the things it fixes. among them are Pantone.
Improves the ability to link markups made in a DWFx file.
Improves the ability to view thumbnail previews in Microsoft
® Windows® XP x64.
Decal bump image map will now import at correct scale for cut-out.
Floors containing multiple slopes and walls will now export to IFC correctly.
Improves the display of colors in shaded views to be more consistent with the 2008 Revit product line.
Export to DXF/DWG will now export the Material's color_map texture.
Mass Floors no longer disappear when adding text to Mass Element comments.
Improves stability of worksharing when saving to central.
Improves visibility of common edges when joining in-place family.
Improves stability when accessing Pantone dialog.
Improves stability when upgrading project or family from the 2008 version of a Revit product.
Improves stability when selecting elements in a 3D view.
Moving a model pattern with a face-based family constrained to it no longer causes a constraint error.
Improves stability when switching between views.
Improves stability when importing DWG files.
Improves performance when adding or editing walls in models with rooms.
Improves stability when creating a section.
When exporting to DWG, the ceiling pattern will now export correctly.
After a project is upgraded to the 2009 version of a Revit product, the linework will now display as set in previous version.
Enables "Show family pre-cut in plan views" parameter for structural framing category family so that the geometry can be cut by the cut plane in medium and fine views.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Door visibility
Thu, Sep 24, 2020 at 8:40:18 AM
Linked File Visibility Management
Thu, Jan 3, 2008 at 6:11:30 AM
Stair visibility issue
Sat, Jan 5, 2013 at 3:19:19 PM
Window visibility in elevations
Tue, Nov 23, 2010 at 9:12:31 AM
View Range Cut Plane Associated Level is wrong
Fri, May 4, 2012 at 11:46:09 AM
Page generation time: 0.7284
