59 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> Brick & frame wall modification
39 Posts No Rating |
I need a brick & frame wall with the brick bottom offset 10" lower than the rest of the wall components. I think there is a way to do this by editing the structure, but I haven't been able to figure it out. Any workable methods will be greatly appreciated. I have attached a PDF of what I need the wall to do. Daryl Stockton
is this what you want http://screencast.com/t/xPjfjXIggYq HTH
Thanks Coreed, I'll give that a try. Daryl
Door in brick wall |
Mon, Jun 25, 2007 at 2:22:07 PM
Help needed with external brick leaf wrap to cover window frame. RA2008 |
Mon, Dec 10, 2007 at 5:24:53 AM
Control Position of Door Frame/Panel in Wall Thicker Than Door Frame |
Thu, May 6, 2010 at 7:29:41 AM
brick sill below window on brick wall |
Thu, Mar 13, 2008 at 6:10:23 PM
Door & HM frame w/ 4" head |
Fri, Dec 21, 2007 at 7:05:40 AM
Members: | 1999820 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
