74 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> To hide sheets from drawing list?
9 Posts No Rating |
hi guys, I'm creating a drawing list, but there are some drawings I dont want to show. Can I hide them some how? Thanx a lot
Like many questions in REVIT, a simple search in your help would answer this question. Look at "drawing list".
9 Posts No Rating |
hi, i found it, but what should i do, if i want to show drawing 100 on list A but not list B??? To omit a sheet from a drawing list - In the Project Browser, right-click the name of the sheet to omit, and click Properties.
- On the Element Properties dialog, clear Appears In Drawing List.
This option is selected for all sheets by default. - Click OK.
Create a new shared parameter - assigned to sheets. Then use that as a filter in your drawing list. Might name it Project phase.... Here is another learning opportunity for you - shared parameters - look it up in the help.
Edited on: Mon, Oct 6, 2008 at 6:48:19 AM
BTW - If your sheet numbers have a prefix like SD then you can filter to exclude those sheets that start with SD. And in another schedule filter for those not containg SD.
Edited on: Mon, Oct 6, 2008 at 7:13:04 AM
9 Posts No Rating |
OMG! it works! the filter thing is smart! thanks a lot for help!!
What if you do not have a sheet but you added some drawings into the Index. How do you hide those?
new sheets - don't want them in my "drawing list" schedule |
Fri, Jan 16, 2009 at 2:43:17 PM
Revit Drawing List |
Tue, Mar 15, 2011 at 5:20:07 PM
Drawing List's |
Wed, May 26, 2010 at 11:49:42 AM
Sheets showing in Architectural Drawing list but not in project browsers? |
Wed, Jan 11, 2012 at 8:08:35 AM
Drawing list sheets are in incorrect order |
Fri, Jul 9, 2010 at 10:59:05 AM
Members: | 2000727 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
