179 Users Online (178 Members):
Forums >> Revit Building >> Technical Support >> Hide a workset in a link
Hello, I'm using Architecture 2009. I may be thinking hypothetically here, but what I would like to do is be able to hide a workset that resides in a link. The reason I would like to do this is so I an globally turn off items copied via copy/monitor by my structural engineer. I thought that if they placed these items on a specific workset, I could reach into the visibility graphics fo rthe link and hide a workset. The workset tab is not available in the visibility graphics for links. Am I missing something? Is there another way to go about this?
29 Posts No Rating |
I found a way to do this. When you load a Revit link, you will see an arrow next to "open" click it and you can view the worksets in your link. You can then specify the links you would like to load from that link. If you want to not see worksets in a link that is allready loaded you can select "reload from" in the manage links to be shown the same options. The only problam I have encountered is that frequently I am given an error that says I have a different workset view than other files. I'm not sure how to address this error. I will re-post with a more descriptive account of this error.
Pipe visibility / workset problem |
Thu, Dec 22, 2011 at 9:02:36 AM
Nested Link in nested link workset control? |
Fri, Feb 28, 2020 at 5:19:24 AM
link model+schedule |
Wed, Nov 28, 2007 at 5:08:30 AM
How to work with the elements from link |
Tue, May 27, 2008 at 12:14:43 PM
Insert/Link CAD Advice |
Wed, Dec 21, 2011 at 2:56:22 PM
Members: | 1990663 | Objects: | 22877 | Forum Posts: | 152180 | Job Listings: | 3 |
