61 Users Online (60 Members):
Forums >> General Discussion >> Revit Project Management >> CAN"T MAKE CENTRAL FILE
16 Posts No Rating |
Our office has been doing quite a bit of work to our template file recently. (generating detail components, standard details, etc) Now when you use our updated template file to start a new project and you go to enable worksets to create a central file an error comes up that says "Element 917889 became corrupt at sometime before this session. To continue with the project save a recovery file.In the recovery file this element will be deleted to fix the problem." How can I fix our template to eliminate this element? I tried to just open the recovery file and resave it as a new template file, but the worksets are already enable and Revit will not allow you to have a template file with worksets enabled. Any help would be great. I have tried everything I can think of. Thanks, Andy
Open your template file. Under Tools click on Element ID. Select by ID. Type in the ID and see if you can delete it.
----------------------------------- BallewDesigns.com |
Template won't allow "make a central file" |
Mon, Jun 23, 2008 at 2:07:08 PM
can't save as a central file |
Wed, Sep 9, 2009 at 2:35:47 PM
"File not saved" |
Mon, Nov 26, 2007 at 5:41:46 PM
setting a central file |
Thu, Apr 17, 2008 at 6:14:40 PM
Can not create local file from Central |
Tue, Mar 6, 2012 at 11:57:26 AM
Members: | 1999820 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
