90 Users Online (89 Members):
Forums >> Community >> Newbies >> cavity around doors & windows
3 Posts No Rating |
when inserting a door or window, i cannot get the 90mm cavity on the sides of the door. first image attached ( untitled1) shows my problem, and the 2nd image attached (joins1) shows how i would want it to look. any help would be most appreciated. thanks
Move one or both of your brick materials in your wall definition and set it to wrap at inserts. Basically... have the cavity be the "core" of your wall.
98 Posts No Rating |
frenchie11, I saw your other post about the wall intersection issue too, so try doing what WWHub said, but only with the exterior brick layer, and set that layer to wrap. Then you'll get the intersections you want on the interior and the wrap you want at the doors.
Door & Window Schedules - how to schedule existing doors and windows |
Tue, Feb 3, 2009 at 11:11:39 AM
Closing Cavity with Plasterboard & Stud |
Fri, Jan 8, 2010 at 1:28:11 AM
Cavity Wall - Cavity Not Filled |
Mon, Jun 16, 2008 at 5:42:38 AM
Shcedulling design option doors & windows from a linked model |
Mon, Mar 19, 2018 at 2:57:51 PM
Excluding doors and windows in count |
Wed, Feb 15, 2006 at 2:59:05 AM
Members: | 1998354 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
