91 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> RA2008 Plan Region Removes Wall Detail Outside of Region
72 Posts No Rating |
Typhoon, I cannot THANK YOU enough for your help. = ) The video is simply the best way to explain your solution. I still do not understand why the First Floor Plan View Properties cut plane fixed the view range problem. But so be it. Thanks again typhoon. Thumbs Up.
----------------------------------- Imagination reveals truths reality obscures. |
You Welcome Prophecy99, the problem is because (like you can see) the "Cut Plane" and "Top Plane" (4' and 10') are in the "Junction" of that vertical Brick with the horizontal brick, if you create those ref. planes at that elevation - 4' and 10' feets - you will see in the south elevation view the line is just coincident with that junction and if you put that "Cut plane" 1" down or up it solve the problem...
Plan region not showing lines in detail view [ 1 2 ] |
Mon, May 11, 2015 at 11:17:48 AM
15
Plan Region not shwoing wall hatch?? |
Mon, Jan 14, 2008 at 12:03:29 PM
Plan Region problem - walls/slabs/framing displaying outside the region boundary |
Tue, Jun 23, 2009 at 4:46:32 PM
Plan Region |
Fri, Jul 21, 2006 at 4:23:10 PM
Masking Region Fill Region Problem |
Mon, Mar 10, 2008 at 11:06:24 AM
Members: | 1993509 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
