78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> RA2008 Plan Region Removes Wall Detail Outside of Region
Thu, Sep 11, 2008 at 7:34:55 AM | RA2008 Plan Region Removes Wall Detail Outside of Region
Prophecy99
Prophecy99 Avatar
Simply put I want to be able to show a high window above the typical cutting plane of the first floor plan.
So of course I went about making a plan region.  Well that works showing the window but also removes any detail in the the rest of the exact wall.  The detail is seen in the plan region as it should be. Just not outside the plan region. It effects only the wall being "regioned".
I searched and couldn't find a legitimate answer to similar questions.
 Thanks in advance.
Imagination reveals truths reality obscures.
Thu, Sep 11, 2008 at 7:53:23 AM | RA2008 Plan Region Removes Wall Detail Outside of Region
3.5 Stars: 390 Votes
Sorry but what are you asking ... saying?  Perhaps a screenshot will clairify it.
Thu, Sep 11, 2008 at 9:11:15 AM | RA2008 Plan Region Removes Wall Detail Outside of Region
fredc83
maybe the plan region you draw is bigger than necessary, try to make your region smaller. It helped with my problems i had about plan regions in the past
Thu, Sep 11, 2008 at 9:52:40 AM | RA2008 Plan Region Removes Wall Detail Outside of Region
Prophecy99
Prophecy99 Avatar
heres a picture
The wall being cut with a plan region is becoming.... invisbile outside the plan region.
Mon, Sep 15, 2008 at 10:05:25 AM | RA2008 Plan Region Removes Wall Detail Outside of Region
Prophecy99
Prophecy99 Avatar
any help would be greatly appreciated....
is this fixed in 09' or something?  We are getting 09' soon and from what I have heard alot of nit picky crap like this has been fixed?
Mon, Sep 15, 2008 at 1:28:47 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
4 Stars: 201 Votes
Did you change the "View Range" in that view???
Tue, Sep 16, 2008 at 11:41:37 AM | RA2008 Plan Region Removes Wall Detail Outside of Region
Prophecy99
Prophecy99 Avatar
I am not sure what you mean? My view ranges for the host view and the plan region are both set to the appropriate levels. I did change the view range in the plan region if thats what your asking.
 The plan region is only affecting the wall it touches. All other walls in the view are as they should be.
And yes your image is exactly what is happening.  Thanks for any input.
Tue, Sep 16, 2008 at 12:39:51 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
4 Stars: 201 Votes
Yeah, i put that image to you see what i did, i just change the "View Range" of that "View Level" and change the the "View Range" in this "Plan Region"...
Tue, Sep 16, 2008 at 12:50:59 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
Prophecy99
Prophecy99 Avatar
Your image is the "problem" i am experiencing........
on the outside of the plan region I want to see the wall like it is on the inside of the plan region.
Bottom Line. I need to see a high window without losing the rest of the wall outside the plan region.
Tue, Sep 16, 2008 at 1:02:18 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
4 Stars: 201 Votes
So, in that view plan write VP then go to "View Range>Edit" and change the "Cut Plane" to down value.... i think your Cut plane in that view plan it's High...
Tue, Sep 16, 2008 at 2:04:44 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
Prophecy99
Prophecy99 Avatar
Appreciate the promt reply.
I tried lowering the top of the floor plan view range as you said.. and didnt get any results.
Here are four picutres.
First two picture show the same... wall same view ranges... one without the plan region on the wall and one with the plan region on the wall.
Last two are showing my view range settings. Which by them selves work as intended.
It is when the plan region cuts into that wall and only that wall that it removes the outside detail of the wall.
Edited on: Tue, Sep 16, 2008 at 2:09:25 PM
Edited on: Tue, Sep 16, 2008 at 2:13:59 PM
Tue, Sep 16, 2008 at 2:14:21 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
4 Stars: 201 Votes
Hi, can you put that wall with the window and that plan region in one file here to download?
Edited on: Tue, Sep 16, 2008 at 2:30:40 PM
Tue, Sep 16, 2008 at 3:12:40 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
#13
Prophecy99
Prophecy99 Avatar
Tue, Sep 16, 2008 at 3:14:10 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
#14
Prophecy99
Prophecy99 Avatar
Here ya go.
I made thee view range and plan region as it is in my project file.
Thanks for your help Typhoon.
Tue, Sep 16, 2008 at 3:50:28 PM | RA2008 Plan Region Removes Wall Detail Outside of Region
#15
4 Stars: 201 Votes
Hi, problem solved, see the video: http://screencast.com/t/TVK7CeT4lfL
i also attached the file changed so you can see the values in the view range of the plan view and the plan region...
Plan region not showing lines in detail view [ 1 2 ]
Mon, May 11, 2015 at 11:17:48 AM
15
Plan Region not shwoing wall hatch??
Mon, Jan 14, 2008 at 12:03:29 PM
Plan Region problem - walls/slabs/framing displaying outside the region boundary
Tue, Jun 23, 2009 at 4:46:32 PM
Plan Region
Fri, Jul 21, 2006 at 4:23:10 PM
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Page generation time: 1.3564
