Forums >> Revit Building >> Technical Support >> Revit 2009 interior rendering isue
14 Posts No Rating |
I am not sure about the service pack. I believe my I.T. person took care of that already, but I will go check. Thanks.
To check, go to "Help" menu in Revit and in bottom "About Revit Architectural 2009..." and check... see the image attach
Edited on: Wed, Sep 3, 2008 at 2:13:55 PM
I checked and the number that is their reads: Build: 20080321_1900 That is different than what you had sent. Does that mean I need to update the SP?
YEAH, go to this: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=11017599 you can check in "WEB UPDATE ENHANCEMENT LIST (PDF)" the issues what this service pack solve, renders problems is one of them... after this you have the link to download the SP....
Do you know if I were to load Revit 2009.1 if that would automatically update with new build number?
I just not sure, but i think he install again the program and "He" don't ask again for the serial numbers, he do automatically that...
I will try loading Revit 2009.1 and if the problem still exist then I know I have a service pack to load. Thanks Typhoon for all of you help today.
You must download the Service Pack and Install them....
Thanks, I will do that.
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ] |
Wed, May 13, 2009 at 7:36:39 AM
22
INTERIOR RENDERING |
Mon, Jul 9, 2007 at 1:02:31 PM
Rendering in Revit 2009 [ 1 2 ] |
Thu, Dec 31, 2009 at 10:41:31 AM
19
Lights not working when Rendering Sun and Articficial? Revit 2009 |
Wed, Mar 17, 2010 at 4:38:51 AM
Interior Rendering |
Tue, Aug 9, 2011 at 10:33:14 AM
Members: | 1997155 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
