Forums >> Revit Building >> Technical Support >> Create sub menu in Project Browser Floor Plan Views
38 Posts No Rating |
User- Revit 2009 I have read a thread on how to create another floor plan view from settings/browser organization, but have failed to see the sub menu created for my enlarged floor plan organization in the project browser. To be simple I have created new sub menus for elevations by just right clicking and crating new view type, but floor plan view does not allow this. A step by step prcedure for creating another floor plan sub folder in the project browser would be a great help. Thanks, Jeff
18 Posts No Rating |
Did you ever figure this out?
We added a "View Group" Project Parameter under the "Views" catagory. I attached a view of the parameter settings. Then we customized a new Browser Configuration to add sub-categories. We set the "View Group" parameter in each view to what kind of view it was, i.e. "Enlarged Floor Plan", "Exterior Glazed Openings", etc.. They show up like the attached image in our Project Browser. I can take more screenshotsor help with specific questions too, if you need.
Revit Architecture 2011 |
This is what I ended up dooing but I don't like the fact that it affects all my other families (elevations, Sections Area plans......). It will make things easier if you could just duplicate the family type for the floor plans. Like you do with elevations. Thanks
do you know if you can also group the Legend and The Schedules? the Parameter is there on the view options but it is not using it to group the views.
No you can't group these.
78 Posts No Rating |
Thanks, this was really helpful
THANK-YOU this has made life a lot easier.
2 Posts No Rating |
Hi All....
thsi smy first experience to explore Revit MEP I have no idea how to control the project browser.
please explain me step by step procedure how to make own disciplins and their sub disciplin.
Regards
RASHEED
Spend some time with your help menu to read up on the project browser, properties, and the discipline options. In order to get a floor plan, elevation etc. to move to the correct discipline you need to click on it in the Project browser, and change the Discipline of it under the Properties.
I do not use MEP but I believe that Sub-disciplines are simply typed into the Properties Palette and then once typed it can be selected in the drop-down list on other views.
2 Posts No Rating |
Thanks Bro..... i am trying...... but result is not in my favour...
plan callout showing up under Floor PLans in project browser |
Thu, Apr 16, 2015 at 1:48:04 PM
Plan in Project Browser |
Fri, Oct 10, 2014 at 9:15:22 AM
Floor plan type |
Sat, May 5, 2012 at 7:07:18 AM
Missing Floor Plan from Browser |
Mon, Nov 5, 2012 at 6:31:47 PM
2nd floor isn't visible in project browser |
Fri, Feb 28, 2014 at 9:55:02 PM
