40 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Enlarge Floor Plans
Wed, Aug 27, 2008 at 4:20:49 PM | Enlarge Floor Plans
blackhawk
3.5 Stars: 3 Votes
Greetings All,
Does anyone know of a technique to create a new TYPE of floor plan. I am having difficulty distinguishing the main floor plans from the enlarged floor plans (created by a callout) and would prefer them to be separated by types, not just all the floor plan views in the floor plan views category. I would like the keep the parameters of the floor plans; as creating an enlarged floor plan in the detail view doesn't allow you as much flexibility.
Sounds confusing? I'll try to clarify. You can create a new 'type' of section within the 'section' system family. How can I acheive this within the 'system family: floor plan'? Wish list maybe?
Thanks
Wed, Aug 27, 2008 at 5:37:52 PM | Enlarge Floor Plans
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
under settings/project parameters
add a parameter to the Views category to define the difference between the views, then in settings/browser organization create a custom setup that groups by your new parameter
next assign the new browser organization to your views in your project browser.
you may now assign different definitions to differents views and they will now seperate via the parameter.
Mon, Sep 8, 2008 at 10:58:34 AM | Enlarge Floor Plans
blackhawk
3.5 Stars: 3 Votes
Thanks for the advice.
The method that I'm going to apply is to just duplicate view for floor plan and then rename it as 'ENLARGED ___'. seems to be the simpliest even though it's less organized.
Tue, Feb 10, 2009 at 1:14:04 PM | Enlarge Floor Plans
twhisker
2 Stars: 4 Votes
Adding a parameter will work, but I am already sorting on type as I have types of sections, details, & elevations.  Why is it that floor, rcp, 3D views, renderings, walkthroughs, & area plans do NOT allow you to create a new type?
I have tried the added parameter, but then I am double sorting on elevations, sections, & drafting views which allow for different types.
If anyone has figured this out - I'd would love to hear about it.
 Thanks.  RAC 2009
Revit Architecture 2010
Tue, Feb 10, 2009 at 2:19:12 PM | Enlarge Floor Plans
Manny
3.5 Stars: 6 Votes
if you duplicate as dependent  this will solve you problem not only duplicate but "as dependent"
Tue, Feb 10, 2009 at 2:37:03 PM | Enlarge Floor Plans
3.5 Stars: 389 Votes
I would suggest that you do not duplicate as a dependant.... you will have many problems.  Duplicate & duplicate with detailing are much better options.... You can always copy added items from one view to the other - just copy paste current view and they will be in the same place.
Wed, Feb 11, 2009 at 9:38:03 AM | Enlarge Floor Plans
jreding
jreding Avatar
I had the same problem as. If I add a paramater it Will Apply to all the views not only to my Floor plan Family. Any other suggestions?
Wed, Feb 11, 2009 at 10:08:56 AM | Enlarge Floor Plans
jreding says " If I add a paramater it Will Apply to all the views not only to my Floor plan Family"
So what?  You don't have to fill it in....  The shared parameter is the way to sort your browser.
Wed, Feb 11, 2009 at 10:22:49 AM | Enlarge Floor Plans
jreding
jreding Avatar
I was thinking more of a way to group them, not sort  them.
Wed, Feb 11, 2009 at 10:37:03 AM | Enlarge Floor Plans
jreding
jreding Avatar
this will explain it better
Thu, Feb 12, 2009 at 11:34:11 AM | Enlarge Floor Plans
#11
twhisker
2 Stars: 4 Votes
AGREED jreding.  I have the same issue.  If i dont fill out my paramter "View Type Group" then I get ???? for the empty ones.  the whole point is to limit the number of + lines I have to drill down into.
 What I did, was to fill that out for all views.  Even though I have a building section, wall, section, and detial section as different types for section family, I filled out my View Type Group.  For floor plans, I used Floor, Enlarged, Roof, and Site to break them out.
 I wish there were more grouping options because 3 is not enough.  My first group is by usage - schematic, presentation, production, working.  The second is by family and the third is by View Type Group which I created.  This works great on one single story building.  We do school campus work.  I would like to further group by building and by floor.
 See attached.
Thu, Feb 12, 2009 at 11:50:05 AM | Enlarge Floor Plans
#12
And if you put the sort name in your view template - it will be there when you apply the template....
We use sub-categories like - Lobby Interior Elevations ... Guestroom Plans.... Guestroom elevations.... Stairs - etc
Thu, Feb 12, 2009 at 4:12:21 PM | Enlarge Floor Plans
#13
twhisker
2 Stars: 4 Votes
YES - thanks WW - I thought of that part just when I hit submit.  I have both the View/Sheet Purpose Group and the Sheet Type Group in my view template - this way I only have to set default view template.  then i apply default view template to all the views and they get their names, sort, and the world is a better place.
Now if only I can get more grouping levels - I'd be a happy camper.  That and a job designing hotels!!!
How to enlarge a complete floor plan
Thu, Oct 28, 2010 at 3:18:04 PM
Best Software to Create Presentation Floor Plans
Fri, Apr 30, 2010 at 12:56:47 AM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS
Mon, Mar 5, 2007 at 2:39:54 PM
Second Floor Floorplan Gone
Wed, Sep 4, 2013 at 8:08:55 AM
Page generation time: 0.4891
