42 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Roof problems!
Roof problems!
Hi,
I have been trying for the past few days to work out how to attach a simple gable roof that extends over a decking. This roof comes off the main roof which is just a straight roof with gables at both ends.
If someone could help I would greatly appreaciate it!
I will send the project file or an image of my problem to anyone that can help.
Thanks in advance!
Dave.
admin
yeah go ahead and send it to me...
hiroshij@oculusinc.com
Hiroshi Jacobs
The Catholic University of America |
41 Posts No Rating |
sounds simple enough - have you tried drawing a reference plane (like a construction line) then edit sketch on the roof? use the align command to bring that roof on out. Now, like they tell me, go to the roof tutorials and you WILL learn a lot about those roofs.
admin
I got your email... but not sure I understand your question... what exactly are you trying to do?
Hiroshi Jacobs
Hmmmm, I know it's hard to describe in text. That small gable roof that extends over the decking needs to be connected directly to the main roof as if it is one whole roof. It must cut into the roof instead of just sitting on top. Also needs to be at same eave height. Any ideas?
Thanks!
Dave.
GO TO ROOF TUTORIALS AND YOU WILL BE DONE AND FINISHED EASIER THAN WE CAN TELL YA - THATS A QUICK FIX, BUT YOU NEED TO LEARN THE BASICS. IT MAY BE AS SIMPLE AS USING THE JOIN ROOFS COMMAND...
Roof design problems |
Fri, Jul 9, 2010 at 7:30:00 AM
12
Roof Problems |
Wed, Mar 5, 2008 at 2:07:33 PM
More roof Problems! |
Wed, Mar 31, 2004 at 2:33:37 AM
Serious problems with roof |
Wed, Nov 24, 2010 at 2:54:46 AM
14
Irregular residential roof |
Mon, Aug 27, 2012 at 3:55:40 AM
12
Members: | 1987480 | Objects: | 22874 | Forum Posts: | 152177 | Job Listings: | 3 |
