54 Users Online (53 Members):
Forums >> Revit Building >> Technical Support >> Revit 2009: Familly with parametric arrays - Voids wont cut
45 Posts No Rating |
Hi all. I've created a counter top with sinks. I've included in the familly sinks and void that are parametrics (array). This way, I can set the number of sinks on the countertop. When I am in the family editor, there is no problem, I can ajust the number of sinks and everythings work fine. The problem is, when I load the family in a project, the parametric arrays works but only the first and last sink void form cuts the counter top. I have attached the familly. Can someone have a look at it and tell me what the problem is? Thanks to all! math.
My guess is because the sink and the void are seperate you need to array the void seperatly. The way I would change this...though it would take a bit of work...is to make the sink family a face baced family and include the void in that making it cut through the host. Then load that and just array the sink family. Transfering your sink into a facebaced could take a bit of work though which is a down side. Might try to make the sink an array with a parameter and the void an seperate array with the same parameter.
Thanks it worked!
Hi, see the video, i don't see any problems with the "Voids" when insert in the project: http://screencast.com/t/I3WJxLyL
Wow Thanks! All the problems are solved!
You welcome.... good for you
Multiple Paramteric Arrays on a beam |
Thu, May 17, 2012 at 3:01:18 AM
Parametric Arrays - Detail Item Help! |
Fri, Jan 29, 2021 at 9:03:59 AM
Array in Family |
Mon, Oct 20, 2008 at 8:20:04 AM
Parametric Arrays |
Fri, Feb 5, 2010 at 3:19:22 AM
Parametric Arrays? |
Wed, Apr 1, 2009 at 3:38:48 PM
Members: | 1997858 | Objects: | 22885 | Forum Posts: | 152179 | Job Listings: | 3 |
