72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Stair railing at the interior corner of a landing
ahahahaha, yeah, i try to avoid create-in-place that element, but if it must be done and there isn't another solution so well... 3D FOREVER.. Thanks Bronco, and lunch of course...
Edited on: Wed, Aug 6, 2008 at 5:59:06 PM
"Revit will not put in a vertical rail and that is exactly what those two instances, geometricly, have to have to get the two railings to connect." Revit will put in a vertical rail. when i get the office tomorrow and have time, i will look up setting and post.
This is a common problem with the railing tool in Revit. What stair fabricators call "cross-overs"- areas where the railing has to adjust at a change in direction. - You can leave it and just draft over this in your section
- You can create an end baluster that has the appropriate sweep / extrusion- then load it into the railing and adjust it into place. (use the railing/handrail ends from the Revit web Library as a template.)
- Model In-place, or create a section box around the stair- export it to cad-open it in a generic family template and model it as a component family.
I would take a shot at making the baluster and loading it in. You have to experience it and decide how much trouble its worth and how much you want it to to be absolutely correct in 3d.
stair railing transition at landing issue (2015) |
Wed, Sep 16, 2015 at 9:29:50 AM
Stair-ramp-landing Problem |
Mon, Mar 24, 2014 at 11:13:25 AM
Starting a Rail on the stair landing. |
Thu, Dec 19, 2013 at 3:01:59 PM
Railings and Stairs |
Fri, May 16, 2014 at 12:12:16 PM
how to connect railing corner? |
Wed, Jan 26, 2011 at 9:26:03 AM
Members: | 2000728 | Objects: | 22886 | Forum Posts: | 152182 | Job Listings: | 3 |
