53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> plan detail callout in section
Fri, Jun 20, 2008 at 10:28:08 AM | plan detail callout in section
gofastwin
revit 2009
windows xp
I have a built up wood column in my current project.  In the floor plans I have a plan detail called out.  On the sheet with the plan detail viewport, I also have a section of the column.  On the section I would like to put some sort of callout refering to the plan detail.  This would be sort of like drawing a horizontal section cut.  My first thought is to place a section tag and use the refer to other view option to mark it for the plan detail.  The problem is revit will not let me refer to a plan detail in a section view.
So what is the work around?  At the moment we have a text note calling the column and referring to the plan detail.  I hate doing this because it defeats the purpose of having tags that automatically update.  So now I am stuck with at least one text with leader that I have to monitor incase I move the detail it is referring to.
 Tim
Tue, Aug 5, 2008 at 3:35:48 PM | plan detail callout in section
Katwoman
I've had the same problem. The reference plane seems to be linked to the location of the line, did you ever have any luck solving this?
Tue, Aug 5, 2008 at 3:51:29 PM | plan detail callout in section
broncos4life
4 Stars: 10 Votes
What I have done in the past when I do this is in the section add a "Section" but have it as a "Detail" vs. "Building Section" or "Wall Section" and I have the section refer to my plan callout.
Tue, Aug 5, 2008 at 3:52:19 PM | plan detail callout in section
3.5 Stars: 391 Votes
Just use a callout, detail that refers to what you want.  Very...very....very small bubble - see attached.
Tue, Aug 5, 2008 at 4:08:10 PM | plan detail callout in section
Katwoman
I'm not sure if I'm following you. Here's a picture of what I'm referring to.
Tue, Aug 5, 2008 at 4:16:39 PM | plan detail callout in section
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can create a section from within the section.  I tend to avoid using detail sections in most cases because they have some strange built in visibility limitations.  You must run it vertical first, then rotate it 90°.
Regards,
Chris.
Tue, Aug 5, 2008 at 4:50:27 PM | plan detail callout in section
As I said, use a callout detail.  This is a section with a callout detail.  The blob at the end of this callout is really the callout bubble.
Tue, Aug 5, 2008 at 5:03:35 PM | plan detail callout in section
Katwoman
Thanks that did it. I was having difficulty changing the family category initially. Cheers. kats
Thu, Aug 7, 2008 at 9:32:56 PM | WWHub
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting WWHub from 2008-08-05 16:50:27
"As I said, use a callout detail.  This is a section with a callout detail.  The blob at the end of this callout is really the callout bubble."
Can't say that I really like that workaround, when its possible to do it correctly.  But hey, if it works...
Sat, Aug 9, 2008 at 11:59:35 PM | how to make a slope column with analytical line
Jayakumar
Mon, Mar 25, 2013 at 5:59:41 PM | plan detail callout in section
NobleLP
Is this still the only way to make a callout that stands alone? I want to add detail callouts in a sudo door schedule or in text
Tue, Mar 26, 2013 at 3:57:11 PM | NobleLP
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Quoting NobleLP from 2013-03-25 17:59:41
With Revit 2013 onwards you could use a view reference tag to do this with the reference other view option.  It can look like whatever you'd like.  I did blog post on it previously:
http://revitrants.blogspot.com.au/2012/10/revit-2013-view-reference-tags.html
Regards,
Chris.
Tue, Mar 26, 2013 at 6:05:24 PM | plan detail callout in section
#13
NobleLP
Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you!
Your the man (more than a man really a GOD)
Wed, Mar 27, 2013 at 12:42:48 AM | plan detail callout in section
#14
axdadmin
In case of Revit 2011 wat i must do.. I dont wanna create view but need symbol .........In view option i found callout which ll create view but i need call out with same view name no along with sim option...........how to get tat option?????/
Fri, Mar 29, 2013 at 11:06:09 AM | plan detail callout in section
#15
NobleLP
So I'am still wondering if a door schedule can have a view referance call out. I assume not, . . . does 2014 address this?
How are we linking a sheeted detail view of a door jamb to the door schedule?
Detail callout vs. Floor plan callout
Mon, Nov 2, 2009 at 11:03:39 AM
CALLOUT DETAIL VIEW VS. PLAN VIEW
Wed, Mar 10, 2010 at 2:04:47 PM
Callout: Detail view vs. Building section RAC 2008
Mon, Sep 24, 2007 at 2:05:38 PM
Detail Component visibility from wall section to detail callout view.
Thu, Oct 8, 2009 at 3:54:42 PM
Building Section and Detail Section Callouts
Mon, Aug 7, 2017 at 5:22:41 PM
Page generation time: 8.8769
