73 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> 24" v 26" monitor
89 Posts No Rating |
g'day, most 24 and 26 monitore do have the same resolution(1920x1200) is there still a gain to be had by using a 26" monitor v a 24"? thanks, robert
If the cost difference is the issue, go for the 24" wide. Are you going for dual screens? If single, 26" is preferable.
G'day, thanks for your promt responce. i got two 21"crt, one is turned off. so at this stage i go for a single. it is not so much the cost factor.the main thing i like to know is that going from 24" to 26" and still have the same resolution effectivly means dropping the the resolution in real terms. would i still benefit from the larger real estate? cheers and thanks
Dell 30" LCD Monitor |
Wed, Sep 6, 2006 at 9:39:56 AM
13
copy/monitor Levels |
Fri, Sep 18, 2009 at 10:24:15 AM
No "ROOMS" tab |
Tue, Jan 13, 2009 at 4:19:33 PM
Large Monitors and Options Bar "Skipping" |
Thu, Apr 23, 2009 at 3:22:06 AM
changing the "family" and "type" names |
Mon, Apr 2, 2007 at 5:33:49 PM
Members: | 1991576 | Objects: | 22879 | Forum Posts: | 152184 | Job Listings: | 3 |
