61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> joining two beams
Thu, Mar 31, 2005 at 10:37:20 PM | joining two beams
timOthyj
4.5 Stars: 14 Votes
Hello in Revit 7.0 which Iam using how do you join to beams together say...I have these two floor beams and I need them to join together to make a square. Also I need to make my ceiling curved.....How do you do that? Thanks a million!!! timOthyj
Fri, Apr 1, 2005 at 12:37:07 AM | RE: joining two beams
timOthyj
4.5 Stars: 14 Votes
actually for the ceiling I meant how do you make a bowed ceiling?
Fri, Apr 1, 2005 at 1:45:38 AM | RE: joining two beams
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you are using structural beams?? Make sure in your family-->family category and parameters the structural material is set to wood... Then they should join together properly... HTH.
Fri, Apr 1, 2005 at 1:46:41 AM | RE: joining two beams
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The bowed ceilng would have to be an -in-place family and an extrusion in elevation to the profile of the bow.
Fri, Apr 1, 2005 at 2:39:47 AM | RE: joining two beams
timOthyj
4.5 Stars: 14 Votes
thanks for the reply... But the material for the beams in steel... I have attached a jpg of the problem
Sun, Apr 3, 2005 at 8:23:03 PM | RE: joining two beams
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes i understand this, but having the structural material set to steel means the elements will not butt join as they leave a gap to allow for a bracket or welding. Changing this structural material to wood will have no architectural effects so unless you are using the data for any structural figures then it won't make any difference to the model. You can still have the architectural material set to steel. HTH.
Tue, Apr 19, 2005 at 11:23:15 AM | RE: joining two beams
thebigG
Hi I've just picked up your post as I have the same problem, sorry to be a but slow but how do you change the beam from steel to wood?
Tue, Apr 19, 2005 at 5:52:51 PM | RE: joining two beams
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the Structural beam family. Go to Settings-->Family Category & Parameters-->in the bottom window there are a couple of options. Change the structural material here.
Tue, Apr 19, 2005 at 6:09:33 PM | RE: joining two beams
ale02
ale02 Avatar
3 Stars: 3 Votes
I think I am having the same problem to join r.c. beams too apart of steel beams. Anyway, Thanks for the workaround, Mr. Spot
Life is never easy but nor it should be complex. Just stay simple Smile
Fri, Jul 6, 2007 at 12:03:10 PM | joining two beams
rsampat
I tried doing this in Revit 9.1 and i am not having any luck. If anyone has a way to do this, i would really appreciate your insight.
BEAMS JOINING COLUMNS problem
Tue, Jun 30, 2015 at 7:41:51 AM
Joining Beams
Tue, Feb 19, 2013 at 9:50:06 AM
Concrete beams joining at expansion joint
Tue, Feb 8, 2011 at 2:04:44 PM
Concrete Beam Not Joining?
Fri, Jul 15, 2011 at 10:59:14 AM
Joining beams to walls and floors
Thu, Jan 15, 2009 at 9:00:36 AM
Page generation time: 0.2879
