56 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Scewing walls
1 Posts No Rating |
Is there a way that I can make a wall go up and over at the same time. i can make a sweep that follows that path and profile bu then it wouldn't "attach" to a roof like a regular vertical wall would. i tryied to rotate a wall off of the z axis and rexit doesn't allow it. some help would be nice. attached is an autocad file with an example of a wall doing what i need it to do
yeah, revit (2008 or 2009) iet, can't permit to rotate a wall off the Z axis, you can create a wall with "Create in Place" with the category "Wall" or create a family "Generic Model" and create parameters to control the angle (see the attached file), but in all off this cases "he" can't "attach" to a roof like a regular wall, the file attached have a (simple "wall" constrain in top to the level, so you can create the wall to the level where is your roof, i think if you explore this situation you can resolve your problem. I hope this what you want.... Reply please Good Luck
there is another way, you can create a mass with the right angle (or a family) and then create walls in the mass element, maybe it' more simple, depend what you want...
Attaching Rails to walls |
Thu, Aug 13, 2009 at 12:59:42 PM
Walls |
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool? |
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
