67 Users Online (66 Members):
Forums >> Revit Building >> Technical Support >> walls like roofs
2 Posts No Rating |
I am using Revit Architecture 2008. I'm fairly new to revit and am trying to make a faceted wall. Is there any way to edit a wall in a similiar manner as making a roof (defining slope lines). I have the shape I want as a roof, unfortunately it's rotated in the wrong direction.
9 Posts No Rating |
Hi, Have you tried any of the following? Unfortunately, you cannot make "slanted" walls in revit (at the moment). Try using >create mass and model your wall/roof the same way you make in place component. You can hide or delete the mass afterwards. If your primary intention is to make a roof, use floors instead of walls to shape your roof. Floors got more surface editing options like slopes and "edit face". If the above doesn't work, try making "in place" component then categorize it under the appropriate family type. Combine blend sweeps/extrusion and voids to achieve varying thicknesses or holes. Hope this helps
2 Posts No Rating |
Much appreciated. I'll give them a try.
Attaching curtain walls to multiple roofs |
Mon, Nov 5, 2012 at 2:19:44 PM
Join 2 roofs, like joining 2 walls |
Wed, Nov 10, 2010 at 7:23:34 AM
How do you convert massings into floors, walls and roofs?? |
Thu, Jul 16, 2009 at 4:48:55 PM
Attached Walls to Roof Issue |
Mon, Feb 11, 2013 at 12:51:20 PM
Walls, Floors and Roofs to show hatch pattern AND color poche? |
Sun, Apr 29, 2012 at 12:24:19 PM
Members: | 1992987 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
