60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Constructing FAMILY
Fri, Apr 18, 2008 at 4:52:24 AM | Constructing FAMILY
nirim
5 Stars: 12 Votes
Hi there
I am trying to build simple canopy roof with only one parameter (attach file) it das look fine but wan I am insert the family in to other project it corrupt and the result is bad. Can someone look at it and tell me what wrong?
nirim
Fri, Apr 18, 2008 at 9:55:26 AM | Constructing FAMILY
Dafpfy
3.5 Stars: 11 Votes
try making a generic model of that roof and loading it in to the familie
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Apr 18, 2008 at 10:01:24 AM | Constructing FAMILY
Dafpfy
3.5 Stars: 11 Votes
and some parts go into the wall so i gues if the roof part gets into place the rest is making the correct locked allignments
peace is the path."
Mahatma Gandhi.
Fri, Apr 18, 2008 at 10:12:24 AM | Constructing FAMILY
Dafpfy
3.5 Stars: 11 Votes
and i would probebly make the triangle things olso in a seperate generic model and then load it into my wallbased model
parameters from families in families can be overtaken with making a new parameter with the same name and then linking it with the square next to the parameter of the familie you loaded into a familie
peace is the path."
Mahatma Gandhi.
Mon, Apr 21, 2008 at 3:21:51 AM | Constructing FAMILY
nirim
5 Stars: 12 Votes
Dafpfy
Thanks for the suggestion I think eventually I got there by taking out some structural elements that was hidden under the roof and can’t be seen anyway, and I also better organized the ‘constrains’, see attached file.
nirim
Constructing a new template
Tue, Dec 4, 2012 at 6:25:33 AM
Constructing a building
Sat, Apr 25, 2009 at 4:11:56 AM
Can a Yes/No Parameter control a Length Parameter?
Wed, Mar 21, 2012 at 9:49:06 AM
transparent roof
Wed, Nov 16, 2005 at 10:32:14 AM
Windows
Thu, Mar 18, 2004 at 8:35:13 AM
Page generation time: 0.7716
